Electric Fan Install ???
HI, I'm all done installing my electric fan in my 05 rem, hemi with A/C. I need to connect one wire to the ac clutch positive wire that activates the clutch. One clutch wire is white, the other is black. Looked at wire diagram in service man, but no info on + or -. Anyone who has done this, which wire is it please?
That AC clutch wire is not needed it was for vehicles that the ac condenser set in front of the radiator, ours are off to the side with their own electric fan to keep the AC unit at the correct temp for optimum cooling.. So just tape it up and leave it off.. You do not need it.. if you hook it up when you turn your heater on in our trucks it will turn the fan on.. making warm up times extremely long on cold days.. ..
Thanks for the replies. Just one problem with the fan. Operates as it should. Up to temp, fan turns on, runs at normal temp. Problem is, when I shut truck off, fan keeps running until temp drops then shuts off. 30 or so seconds later, fan comes on again, slows then off. It does this one more time, all while truck is off and key is in my pocket. Checked wiring 4 times, all exactly the way instructions show. Any ideas?
Trending Topics
