2005 hemi ram , po300 , I'm out of ideas
So it was a high mileage truck , started missing on cylinder 5 and then eventually po300. So I did the usual stuff copper 570 plugs , wires , then tried new coils , injectors and still skipping. So I did a compression test and #5 was only 50 psi , #8 was worse. So I pulled it and did a full rebuild. It's still skipping ....... So I also replaced the cam and crank sensors , as well as the egr valve. My fuel pressure was 60psi so I'm not thinking it's a fuel delivery problem ? The throttle body was cleaned when I did the plugs as well. Since the rebuild I again replaced the plugs , this is where I'm at a loss. Cylinders 2 and 6 had dirty plugs as well as 1 and 5. I did pull the injection/coil harness to inspect it , all looked good. The truck idles a little rough and it misses to the point of shaking under light load or cruising , the truck has an audible miss at higher rpms. I have tried resetting the pcm , pulling the wires overnight and touching them together etc. What am I missing ?
Yes I disassembled them and sent them with the block to get checked and washed. They cut .011 to square them up , and then I reassembled them with new seals and replacement springs. I used dye-chem to check the valves have good a seal to the seats.
Trending Topics
Figured it out
So it turns out that 4 of the " new " injectors were in fact faulty. I performed a injector flow rate test and two were intermittently malfunctioning and two others were not within accepted parameters . So I dug the old ones out of the bottom of the old parts box and cleaned them cleaned them out and installed them with new screens and I rings . Now it's running fine and no more codes !
The following users liked this post:
lxman1 (11-29-2020)
At least its fixed.
