3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I did some work on my 03 1500 5.9 magnum and forgot to put the lower radiator hose clamp back on. When the water started to spray I turned off the engine and put the clamp on but now the engine will not start. I have since changed the Ignition coil and crankshaft sensor. As far as I can tell I have no power going through the Ignition coil. Any help would be appreciated.
Did you happen to drive it before you noticed the water spraying?
