Air coming from every vent. (Main/Defrost/Floor)
Hi Everyone,
I recently inherited my Grandfathers Ram after he passed away from Covid last year and Im trying to do right by him and keep it well maintained. It only had 92K miles on it and was garage kept. Im having a few minor issues and Ive been tinkering with them and having some success. However, my AC issue is driving me nuts. Im getting air from every vent in the truck. The main, floor and defrost vents. Turning the dial to change the vent does nothing. Ive checked the forum, google and youtube and couldn't find an issue where someone mentioned getting air from every vent.
I read that if it were air only coming from the defrost or no air coming to floor vents then it was probably a vacuum issue or possibly issues with the vent doors. In my case should I replace the entire climate control module in the dash or.....?
Thanks in advance for your time and assistance. I hope everyone is doing well!
I agree it’s weird air coming out everywhere.
Hi, thanks for the reply. I do not hear any clicks at all when changing the dial. I'm pretty sure the center bezel was never removed but I could be wrong. The AC control is around $130ish +/-. Im wondering if I should just replace it.
Trending Topics
You can check your current A/C control. How good are you with a multimeter?
You'll need to disconnect and remove the control.
The way I understand the control to work is by opening ground in each position. The check would be to ensure ground continuity changes between pins as you move the ****.
You can also check the resistor in the blower motor, but I think your problem is air coming out of all vents so blower motor is likely working fine.
