“New” muffler exhaust flow direction
Old 11-07-2022, 05:37 PM
pwinks12's Avatar
pwinks12
pwinks12 is offline
Default “New” muffler exhaust flow direction
curious about flow direction, you should be able to see it in photo, but facing (close) side says “inlet” with an arrow pointing down to other (far) side…. Not sure how to take this- sometimes arrow means flow direction, sometimes no… Only diagram I can find for this muffler shows (maybe) far side as inlet? Part number is 55366752AA
Old 11-07-2022, 07:36 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,226 Likes on 2,976 Posts
Yeah, now that IS confusing...... Have a look at the hangars. Should be able to tell how it installs that way.
Old 11-08-2022, 09:03 AM
pwinks12's Avatar
pwinks12
pwinks12 is offline
Hangers do somewhat tell a story, there is one in front, two in back- muffler has same configuration but will require a bit of fabrication to get a good hang height— if they work out to be the same direction.
Old muffler was Magnaflow that came with it, nice sound but I want it quieter now that it’s rusted out.
Seems like inlet would be close side relative to photo, with flow arrow. But it’s an odd one. I was hoping someone familiar with Mopar mufflers could confirm
Old 11-08-2022, 12:39 PM
Magnoom's Avatar
Magnoom
Magnoom is offline
It's pointing to the inlet.
The following users liked this post:
pwinks12 (11-08-2022)
Old 11-08-2022, 01:43 PM
pwinks12's Avatar
pwinks12
pwinks12 is offline
Ok, I’ll take your word for it! That jives with the hangers too, so I think you’re right. Thanks!
Old 11-09-2022, 04:53 PM
Magnoom's Avatar
Magnoom
Magnoom is offline
The lack of experienced mechanics lol.....most mufflers (any of the ones I have seen in 30+ yrs) simply tell you where the "inlet" is, whether it is directly labeled (see below) or pointed to.
Old 11-09-2022, 06:26 PM
HeyYou is offline
Depends on the manufacturer. When I did exhaust for a living, very few of our mufflers told ya when end was which. The inlet pipe was generally a bit larger than outlet, (assuming both were the 'same' size) simply because of the way ya run pipe.
Old 11-10-2022, 09:12 AM
Magnoom's Avatar
Magnoom
Magnoom is offline
How long ago was that though.....?
Old 11-10-2022, 09:51 AM
HeyYou is offline
Oh, about 200 years.
Old 11-11-2022, 02:22 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
Did you measure the pipe on each end? Inlet should probably be smaller than outlet.
See the hangers in this diagram... I googled the part number in your pic.
https://www.moparpartsgiant.com/part...5366752aa.html
Quick Reply: “New” muffler exhaust flow direction
