Last edit by: IB Advertising
Browse all: Electrical System
- Dodge Ram 2nd Gen How to Replace Starter
Step by step instructions for the do-it-yourself repairs.
how do i change the starter help!
so i'm about to change the starter for my mom's 1998 grand caravan. i understand there are 2 bolts holding it in? after i unbolt those and unhook the power, am i good? any other complications? i read that you need to use a special wrench for the top bolt or something? need to get this done tomorow. thanks
Before you get too excited, slide under and take a good look. I just did one on my '96 3.3 liter and it was a PITA. The engineers were kind enough to put a motor mount in front of the starter so I was working blind in replacing (taking bolts out). Also the spacer (gasket ) has a flange on one side that goes against the bell housing and the bolts are long so do not worry about if they are ever coming out. You can do it but may qualify for a Purple Heart after words
Took about two hours and you may need some universals on the ratchet extension. Thee boltw were super long and I thought they were never coming out. The gasket may fall out as you take the bolts out, however the bolts go back through the gasket so that is not a problem. The biggest problem was working blind, a lot of this is by feel, so go under and take a look.
ooh ok cool. im about to do it right now, but i see theres an outlet or something that's disconnected. i do not know what this is for and where it connects to. doesnt seem like it connects to the starter because i see no inlet. anyone help? thanks
i can't find the top bolt either. and i THINK i found the bottom bolt. any advice? can't see a thing down there, i know what you mean vabear.
Trending Topics
oh thanks! so i'm guessing the car does not have one? it should since it has the plug right? where would it be located? i didnt find anything like it around the area. the check engine light is on could this be why? i thought the CEL was on because of the bad starter.
