power window problem
Had the power window on the drivers side replaced.
Then the passenger side stoppped working.
I decided too do it my self this time.
But before i baought a new motor. I checked the power too the motor.
I have no power at the motor. I then hooked up a seperate power source too the motor and it works.
So, any suggestions to why i dont have any power going too the motor when i hit the up or down button. Even drivers button wont send power too the motor.
Thanks for any help
mike
Thanks for any help
mike
Trending Topics
It's the wire harness that connects to the buttom of the window switch panel inside the driver's door. In order to change the drivers door window motor they had to remove the door trim panel. The switch assembly is mounted to the trim panel. They would have to disconnect the switch panel harness to remove the trim panel.
