Please help!!!!! 01 24valve cummins
Old 03-22-2017, 12:13 AM
Cts92's Avatar
Cts92
Cts92 is offline
Default Please help!!!!! 01 24valve cummins
Got a brand new starter just put it in today! jumped my truck cuz batteries were dead. It started up i drove it home and after an hr i went outside to start it to make sure my batteries were not dead and the key just turns everything on my dash works headlights i have everything lift punp eorks just no noise from my starter please help!!!!!
Old 03-22-2017, 07:43 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,190 Likes on 2,943 Posts
Check the starter relay in the PDC. Beyond that, may wanna post in the Ram Diesel section.
Welcome to DF!
Old 03-23-2017, 10:27 PM
p38251's Avatar
p38251
p38251 is offline
Sounds like a battery issue. How old are the batteries?
Old 03-28-2017, 01:46 PM
Cts92's Avatar
Cts92
Cts92 is offline
I got new batteries about 4-5 months ago i was told it could be my positive cables from my batteries so im going to replace them i just dont get it it will start just fine and then it wont but you can hear a ticking noise then it will start again sometimes it will grind to
Old 03-31-2017, 09:28 AM
nibroc's Avatar
nibroc
nibroc is offline
clean all cable connections
Old 04-03-2017, 09:00 PM
Cts92's Avatar
Cts92
Cts92 is offline
All cables cleaned replaced my main positive from battery to the starter ($66 bucks at napa) still nothing... Wondering if it could be my ignition switch. Batteries were tested and they are 89% charged so there good but im stumped
Old 04-04-2017, 12:41 PM
Cts92's Avatar
Cts92
Cts92 is offline
Default Still in need of help if anyone has it! 2001 dodge ram 5.9 cummins
Truck wont start ! Put in a new starter starts every now and then got batteries tested 89% each there good. Cleaned all grounds got new positive cable at napa ($66) put that in still nothing. You can hear a tick when i turn it over like the egnition switch hitting but the starter will not turn any advice?! The sensors are good as well
Old 04-04-2017, 12:51 PM
jkeaton is offline
Moved to the correct section and merged with you existing thread.
Old 04-04-2017, 06:06 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
See if you can jump the starter... Would not be surprised if the part store one is junk... I ended up spending 29.00 to rebuild my factory denso and have been very happy with the decision
Old 04-04-2017, 09:49 PM
Cts92's Avatar
Cts92
Cts92 is offline
Should i waste my time or just send it back? Its under warrenty so i might as well get a new one lol but if thats not it i have no idea what to do lol thanks for the reply! And jkeaton idk what you mean
