Gravel type noise when using air con
Old 07-09-2023, 03:36 AM
Markin's Avatar
Markin
Markin is offline
Default Gravel type noise when using air con
Hey guys,
So I just got back from my first long trip with my 1994 Dodge Ram Van. All went well really. Nice and comfortable and roomy for my son and I. I have to admit, the air con was so so for the entire trip. It doesnīt blow that well, but hey, itīs old I though. Then it started playing up. The first thing that happened was that if it was left on for a long time it stopped blowing. So I had to press the off button, turn the fan controller to off, then turn them back on again to get it working. it would work for a while then shut of again. Ao anyway, for the journey back home yesterday, we left early so no need for air con straight away. But about 350Km from home we stopped to relieve ourselves and my son asked for the air con as it was getting warm on the back seat. So I switched in on then started moving, and there was this sound, similiar to when you are on a gravel drive and the tiny stones are hitting the underside of the car, but with a more metallic sound. It seemed odd as I didnīt see gravel on the road surface. So I stopped and the noise continued even whilst stopped. I drove a further 20m and the noise got stronger. So I stopped and looked underneath to see if it was something falling off the underside, but nothing. So I opened the hood and the noise was clearly from the engine bay. The belts I could see looked a bit floppy. So anyway, I switched off the aircon and after a further 50m the noise stopped. Anyone had anything similar to this? My thinking is that the air con accessory belt was breaking up or something like that. Is this van belt drive or chain driven?
I will have to take it back to the mechanic this week to get it looked at. Impossible to be in Spain without air con. I will get them to check and replace all belts just to be on the safe side.
Old 07-09-2023, 09:41 AM
jeffersonracing's Avatar
jeffersonracing
jeffersonracing is offline
You have a belt that drives everything, but I doubt that is the source of the noise. I am thinking the clutch on the compressor is going south.
Old 07-09-2023, 12:06 PM
nibroc's Avatar
nibroc
nibroc is offline
Old 07-09-2023, 01:07 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,244 Likes on 2,993 Posts
If it only crunches and grinds while the clutch is engaged, that's a failing compressor.
Old 07-09-2023, 03:38 PM
Markin's Avatar
Markin
Markin is offline
It is almost like a tinkling sound of bits being thrown again the engine and radiator, not grinding or crunching.
Old 07-09-2023, 04:45 PM
HeyYou is offline
Does it only make the noise when the compressor is engaged?
Old 07-09-2023, 05:29 PM
Markin's Avatar
Markin
Markin is offline
Yes, only when I switch it on
Old 07-10-2023, 09:35 AM
HeyYou is offline
Sounds like the compressor is failing.
Old 07-10-2023, 09:44 AM
Markin's Avatar
Markin
Markin is offline
OK, thanks for the guidance. I will take it to the shop this week so they can check it over, but looks like another order I will be placing to Rockauto
Old 07-11-2023, 12:18 PM
Markin's Avatar
Markin
Markin is offline
So the mechanic canīt take the van in until next week which is a bummer, but it is what it is. Anyway, in the meantime I jut went to the van and took some photos, and I am leaning towards the tinkling noise of things hitting other parts of the engine, being bits of the belt. here are some photos of the belt and it looks like it is starting to disintegrate
Quick Reply: Gravel type noise when using air con
