Newb looking into car and modding
Old Jul 27, 2004 | 05:51 PM
  #31
srt4driver's Avatar
srt4driver
Default RE: Newb looking into car and modding
thanks for all the great help guys. i really appreciate it. just put in an order for the stg 1, agp wastegate, and bdjs 3" race exhaust with 3" o2 housing. hoping to get some nice little gains off of this stuff. thanks again.
Old Jul 27, 2004 | 06:22 PM
  #32
dustyloins's Avatar
dustyloins
Hall of Fame Member
You'll enjoy the Stage 1....the exhaust is noiser when you let off the gas, the boost starts earlier and you get more of it resulting in a "whoosh" sound of air followed by the "whistle" of the turbo (kinda reminds you of a jet), launches are more powerful and the BOV is more pronounced. It's great sound entertainment while you drive the car in addition to giving you more power!
Old Jul 27, 2004 | 07:11 PM
  #33
roachnigga's Avatar
roachnigga
You'll recieve some serious gains with those bolt-ons. But, like i've experience, mentioned b4, you'll lose a little low-en tq and recieve it on the mid-high end....
ORIGINAL: srt4driver
Old Jul 28, 2004 | 01:24 PM
  #34
71RoadRunner's Avatar
71RoadRunner
Yep, and that will just help you out with launching with less wheel spin.
Old Jul 30, 2004 | 08:26 PM
  #35
srt4driver's Avatar
srt4driver
a couple quick questions...
1)will i need motor mounts for this set up or should i be good?
2)which intake aem or injen and should i get it?
3)what else to do so i can run high 12s?
Old Jul 30, 2004 | 08:33 PM
  #36
dustyloins's Avatar
dustyloins
Hall of Fame Member
Stage 1 probably won't get you into the high 12's, but low 13s are no problem. You can always opt for Stage 2......
Yes, motor mounts will reduce the wheel hop. But as was said before, that torgue/force has to go SOMEWHERE.....
Old Jul 31, 2004 | 06:36 AM
  #37
71RoadRunner
I know of several Stage 1 equipped SRT-4's that are in the 12's with a few other bolt-ons, like the exhaust, CAI, WGA, etc.
Just get a set of motor mount inserts, cat-back or turbo back exhaust, CAI, STS and at least Stage 1 and as long as you can launch it properly, you should be very solidly in the 12's.
Old Aug 2, 2004 | 08:09 AM
  #38
srt4driver's Avatar
srt4driver
is it possible for you to give me the links to these cars or the threads they are on??? also, would it be a good idea to throw in injen short ram and sts w/ booger bushings? i want to be in 12s solid
Old Aug 2, 2004 | 10:51 AM
  #39
71RoadRunner
You will find most of the 12 second Stage 1 SRT-4's on the srtforums.com. The Mopar STS w/booger bushings is a great mod. I myself prefer the K & N Typhoon CAI, but the Injen short ram will still be a little better than stock. Since the short ram intakes draw in hot under hood air they are less efficient and effective than the factory set up that draws air in from outside the engine compartment, but it will flow more air than stock since it is larger and smoother. A great cheap and easy mod that will make you quicker in the 1/4 mile is a set of motor mount inserts, you can get the Prothane race inserts for only $23.99 for the pair.
Old Aug 2, 2004 | 04:16 PM
  #40
srt4driver's Avatar
srt4driver
which is better with the motor mount inserts race or streeet? i need my car for everyday use and i dont wanna mess anything up.
