mopar sts
Old 02-06-2007, 02:44 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
Default mopar sts
how much shorter is the mopar? a guy has one for 60$....is this good/ worth the money? i want one thats goin to be signifigantly shorter....would this be what im lookin for?
Old 02-06-2007, 03:36 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
Default RE: mopar sts
not at all. it's about 28% shorter. check the maddog, you can get them as much as 82% shorter.
Old 02-06-2007, 03:56 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
how hard of an install is it?
Old 02-06-2007, 04:53 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
can neone find a b/g install how to? im looking but can seem to find one anywhere
Old 02-06-2007, 05:05 PM
Aceburner's Avatar
Aceburner
Aceburner is offline
Well I dunno about the SRT but i installed one on my probe. Since it was my first car its was a headache and a half. It consisted of removing the boot, snap rings, and crap from the top then going underneath the car and disconnecting the shifter from the shift lever and installing the new one in reverse order. It's wasn't that bad and if I had to do another on it probably would take me about 30 to 45 mins at the most. They are pretty easy. I'll help to look for an install since I need to do one also. PSI Chick, where can we check out the maddog?
Old 02-06-2007, 05:14 PM
Aceburner's Avatar
Aceburner
Here I found a place for it, I dunno if it's really for a SRT but it's a STS install from Mopar so i'm guessing it is.
http://forum.neoncanada.com/index.php?showtutorial=19
Old 02-06-2007, 05:16 PM
Aceburner's Avatar
Aceburner
I found an even better site.. here take a look at this... this is for sure for SRT's
http://www.srtsyndicate.com/archive/index.php/f-77.html
Old 02-06-2007, 05:48 PM
PSI Chick's Avatar
PSI Chick
www.maddogsts.com
it takes 20min-30min to install a shifter your first time. if you're not doing bushings it's even shorter.
Old 02-06-2007, 06:15 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
anyhting on a boost gauge....i just went and got one on my luch break and want to put it in tonight
Old 02-06-2007, 06:42 PM
Aceburner's Avatar
Aceburner
Ok let me ask a quick question then, what does it mean by 50%- 80% reduction, and should Iget bushings?
Quick Reply: mopar sts
