Old Jan 1, 2018 | 11:58 AM
  #16001
adukart's Avatar
adukart
So, you can drive to work on just the battery/starter motor?
Yes You know how it is since you live over in Michigan. When you get -15F and colder it become imperative to have as many CCA's as possible. Yesterday morning thermometer said -28F and it fired right up.
Also replaced my front shocks.
Old Jan 1, 2018 | 12:38 PM
  #16002
Yup. That's why when it comes to battery replacement time, I get the biggest, meanest battery that will physically fit.
Old Jan 7, 2018 | 02:18 PM
  #16003
Jimythefan's Avatar
Jimythefan
Originally Posted by 5.9_MAGNUM_POWER
I added a new touchscreen and speakers
Okay, we need way more info and pics on this. That's just a tease.
Old Jan 7, 2018 | 11:02 PM
  #16004
adukart's Avatar
adukart
+1 I am looking at putting in a back up camera and would like to do this without motorized screen single din.
Old Jan 9, 2018 | 03:31 AM
  #16005
Ramman18's Avatar
Ramman18
Replaced a radiator on a friend's 2012 Journey. Wow, what a job. I'd rather do my clutch again. Stupid little cars. . .
Old Jan 12, 2018 | 02:34 PM
  #16006
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
New Tires and Rims
Old Jan 12, 2018 | 02:40 PM
  #16007
MoparFanatic21
Originally Posted by Ramman18
What's option three?
How would I eliminate the hydraulics? I've thought about it, since big rigs don't use hydros. It's gotta be the clutch itself or something going bad in the trans I guess. Or I didn't donate change to the Salvation Army ringers or something.
Option 3 is use as a lawn piece. The hydraulics would need to be removed (slave cylinder, lines, and reservoir) and a older ram clutch system put in 86 and back. 87 and newer is when they started hydraulics.
Old Jan 12, 2018 | 11:14 PM
  #16008
Ramman18's Avatar
Ramman18
Got a link? According to rockauto, hydros were used already in 85 and they list nothing before that. Even then, the 85 and up master cylinder is a completely different design. Unless you've done this and can recommend parts, I'll keep looking.
Old Jan 29, 2018 | 01:06 PM
  #16009
horace's Avatar
horace
Default squeaK
i REPLACED a steering dampener to eliminate a harsh unpleasant SQUEAK! Long needed
Old Feb 4, 2018 | 02:24 PM
  #16010
adukart's Avatar
adukart
Re-spooled the winch with a synthetic rope, found out the PO had duct taped the cable back on after breaking the mount bolt in the drum
