Need advice for limited slip rebuild
I just got done reading a different thread on limited slips and found out when jacked up both tires should spin the same way, mine doesn't. I have a limited slip. According to this forum that means that the clutch disks are shot? I need some advice. Can I drive it in this condition? Where should I get parts from, ect. Thanks for any input you may have!
ok first off get the build sheet anyways just to be sure... here's a site... enter your vin number and it will tell you... not as good as dodge's official one but it works...
http://www.compnine.com/vid.php?vin=1b4hs28n11f505789
i take it you blocked the front wheels, jacked up the whole rear end and put it in neutral... what did the tires do... you said they didn't... you mean they didn't spin or spin the same way... did they spin oposite?
Trending Topics
