Ever seen a tool like this?
Old 09-02-2012, 09:46 PM
durandall05's Avatar
durandall05
durandall05 is offline
Default Ever seen a tool like this?
No, I'll bet not.
I made this pulley holder to remove my fan clutch. That SOB will not budge. I soaked it over night with PB Blaster, installed this bad boy grabbed on with a huge wrench and nothing.
Lefty loosey correct? When I say left I am facing the truck and turning towards the passenger side.
Anybody have any tips on how to break this thing lose?
Old 09-02-2012, 09:57 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Interesting?
It may be a reverse thread I replaced my clutch last year but dont remember but my nut came off easy.
Try the reverse way I think it was a reverse thread
Old 09-02-2012, 10:06 PM
durandall05
Thanks for posting up. All the information I could find said it was standard thread. The new clutch is also standard thread.
I guess it is possible it is reverse thread, stranger things have happened...
Old 09-02-2012, 10:10 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Do you have any pic's of the compressor and the clutch?
Damned if I can remember if it was a reverse thread?
Old 09-02-2012, 10:12 PM
durandall05
Ya I'll run down there and take a couple.
Old 09-02-2012, 10:15 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
ooops you are talking about your rad fan clutch
Im thinking A/C compresor clutch
Cant help with that sorry
Old 09-02-2012, 10:21 PM
durandall05
Ok here are some pics. The last two are the new clutch that are waiting to go in.
Old 09-02-2012, 10:24 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Good luck with that I know lots of other people have replaced these on the forum
But not me sorry I miss understood your problem
Old 09-02-2012, 10:30 PM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
That is some cool tool fabrication..The first time I had to remove my fan clutch I rented the removal tool kit from Auto Zone and that did not work very well. I used the spanner wrench from the kit and stuck bolts in two of the holes on the water pump pulley and held the spanner wrench against the bolts, kind of the same principle as the tool you have fabbed up there. I put a big ole adjustable wrench on the fan clutch nut and had to whack the handle of the wrench a few times with a big hammer to pop the nut loose. If you have a 4-cylinder I think the nut is left hand thread. On a V6 or V8 it is standard right hand thread, so you need to turn or whack the nut towards the passenger's fender to remove it. Also the fan itself has two blades that are further apart than the others. Turn the fan so the wider space is up, so you have better access to the fan clutch nut.
Jimmy
Old 09-02-2012, 10:54 PM
durandall05
Thanks for the tip about the fan Jimmy, that should prove helpful when I go back at it.
I guess I am going to break out the torch and see what happens.
Quick Reply: Ever seen a tool like this?
