97 Dodge Dakota Issues
Old 01-29-2020, 01:02 AM
Micah Enke's Avatar
Micah Enke
Micah Enke is offline
Default 97 Dodge Dakota Issues
Hi, Y'all first time posting here i have been scouring the internet and my chiltons manual for a fix for this truck so heres the issue. I have no speedometer, or odometer and the check engine, abs and brake light are on. I have replace both the VSS and the ABS sensor in the differential and it made no difference. I cannot locate the ABS module for this truck i have looked just about everywhere and cant find it. This is very frustrating as i dont have any clue to find it any help would be appreciated thanks.
Old 01-29-2020, 08:01 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,290 Likes on 3,037 Posts
See if you are getting 5 volts TO the VSS.
The following users liked this post:
Micah Enke (01-29-2020)
Old 01-29-2020, 10:47 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
The ABS module should be located near the brake master cylinder. You'll have it on top of the pump if 4 wheel ABS and by the valve assembly if RWAL.
They do need to be programmed to the truck.
Old 01-29-2020, 11:50 AM
Micah Enke's Avatar
Micah Enke
there is 5 volts going to the sensor. I will post pics later of the engine bay maybe you can spot it its nowhere to be found i wonder if someone took it out
Old 01-29-2020, 12:26 PM
Micah Enke's Avatar
Micah Enke
Old 01-29-2020, 06:39 PM
HeyYou is offline
From left to right, it goes Master Cylinder, proportioning valve, dump valve. (the abs valve.) You have rear wheel abs only.
Old 01-29-2020, 07:39 PM
Micah Enke's Avatar
Micah Enke
ahh ok so i do not have a abs module im still testing 5 volts the ground is good i have no idea where to look at next
Old 01-29-2020, 07:46 PM
Micah Enke's Avatar
Micah Enke
Ok so update abs and brake light are off after cleaning off contacts and everything but still no speedometer and odometer
Old 01-29-2020, 08:03 PM
HeyYou is offline
On yours, those are driven by the ABS. I *think* you can do a cluster test, by holding in the trip/reset button, and turning the ignition to "on". The cluster will turn on all the lights, and sweep all the gauges. See if the speedo moves.
Old 01-29-2020, 08:28 PM
Micah Enke's Avatar
Micah Enke
yes sir the speedo does move so its not a cluster problem the VSS itself the ground is good the orange and white wire is sending 10 to 12 volts as well as the the other wire not the ground which seems weird as it supposed to be 5 volts no?
Quick Reply: 97 Dodge Dakota Issues
