Old May 13, 2013 | 08:03 PM
  #11081
wellsj's Avatar
wellsj
Originally Posted by Wombat Ranger
How much did you pay?
1600 but then bought 42lb injectors hemi fever tune and 2 bar map sensor
Old May 13, 2013 | 08:10 PM
  #11082
Wombat Ranger's Avatar
Wombat Ranger
How much boost you plan to run? Planning on studs etc?
Old May 13, 2013 | 08:11 PM
  #11083
wellsj's Avatar
wellsj
just the standard 6 for now. not trying for anything crazy, just wanted a little more power. in the future, probably studs and 11 lbs
Old May 13, 2013 | 11:06 PM
  #11084
Wombat Ranger
Are you gonna put a new intake manifold on it? The blowout prone kegger probably wouldn't like boost.
Old May 14, 2013 | 06:49 AM
  #11085
renardk764's Avatar
renardk764
The kenn bell should replace the intake manifold. The far right spot on the aluminum piece with the oval hole and four bolt holes should be where the throttle body mounts. One thing to check is the neck with the pulley. There's a bolt inside the neck that hold the gears in place that has a tendency to loosen up with multiple installs. It ends up backing out and not engaging the gears. They rely on position and friction. Easy fix. Make sure Ti keep every thing clean and install a good catch can for pcv oil blow by.
Nice!
Old May 14, 2013 | 10:40 AM
  #11086
Wombat Ranger
^^ Gotcha. I don't know much about superchargers beyond how they work and what they do to get their results.
Old May 14, 2013 | 10:48 AM
  #11087
redneck_ram's Avatar
redneck_ram
the things i would do to get my hands on a blower... i already have arp head studs, and a pretty decently built motor...... need to find one!!!
Old May 14, 2013 | 12:58 PM
  #11088
Jigabop's Avatar
Jigabop
I'll take a supercharger
boost at idle! no turbo lag oh my...
Old May 14, 2013 | 03:09 PM
  #11089
QuadCabLuv's Avatar
QuadCabLuv
Why not both? I have seen many a SC fed by a TC.
Old May 15, 2013 | 06:52 AM
  #11090
renardk764's Avatar
renardk764
I don't know if you got the install instructions with the unit, but if you didn't contact Kenn bell. Their instructions are very step by step and easy to follow. We used then on the install for my neighbors charger srt8. The only problem we tsb into was that neck bolt issue. Oh, and when my neighbor left a plastic glove in the air intake tube that got sucked into the throttle body. That was scary.
