If you're Cat is clogging up, headers won't help much, until the downstream issues are fixed.
Got oil, filter, and a block heater at oreileys than went to the dealership and ordered some new hose clamps to replace the crappy worm drive ones when I put the block heater in and ordered sway bar bolts. Lastly I got my new tires mounted. No pics of the tires yet since it was dark when I picked it up.
Picked up my hose clamps at the dealership, and for kicks checked if I could get a fuel line for my truck since mine is patched. To my surprise I can, and for only $70 something dollars before my discount! For some reason I thought it was discontinued or stupid expensive. So I ordered that. Also picked up a puller at harbor freight for my power steering pump replacement.
Now that's cold! Only been -20F (-28C) here so far. Haven't tried to start the '95 V-10 this winter.
My '09 1500 starts fine, but it's in the garage at night, which stays around 20* warmer than the outside temp.
My Jeep has been starting, installed a new 880 CCA battery last fall.
Fire it up every couple of days and let it run for a bit. Trans doesn't like the cold at all! (32rh in the '00 Jeep TJ)
