Old May 23, 2010 | 02:25 AM
  #3801
lastrights's Avatar
lastrights
Originally Posted by Eric99ram
Cleaned the engine bay a little in preparation for this weekends project but I'm going to need to get a shop vac and/or a compressor and blow all the crap that's built up in between the intake manifold and the valve covers. Also removed the hood liner finally and cleaned the hood up a bit. Glad to see it gone finally but now I can't help but to want to get it touched up with fresh paint...lol. Also finally pulled the pinstripes, dodge, and 4x4 badges off the tailgate. Depending on how things go, either I'll finish debadges the rest of my truck to include the rubber stripes along the sides and the plastic piece on the tailgate or I might wait and let whatever body shop I take her to get repainted sometime soon remove it all and make sure they don't reinstall any of it.
i would tae it off your self it saves some time to get the black off the tailgate and stuff would save you labor of them doing it
Old May 23, 2010 | 02:28 AM
  #3802
canada_rokzz's Avatar
canada_rokzz
Love the switch plate.
FAR more useful than the 'cupholder' that was there originally. Got a DIY article for that?
  1. Remove useless cupholder from dash.
  2. Break off (if they are not already broken off) the part that holds the bottom of the cup. this will make room for the wires to pass through later.
  3. While holding the entire assembly in a vice, use a hack saw to cut the face off the existing cup holder.
  4. Use the piece you just cut off as a template to make a new face. Choose what ever you like, that is going to be stable enough to hold your new switches. (I used 1/8" aluminum plate, and used 180 grit emery cloth to finish it.)
  5. Drill holes in the new plate for your switches. Not every switch is going to be the same, so measure the shaft that will go through the hole. I used a 1/2" bit for all my switches.
  6. Line up the plate with the remainder of the cup holder, so you can remove plastic from the cup holder to allow room for the end of the switch/wires to come through.
  7. Once you are sure you have this right, epoxy the face to the remaining cup holder. I used LePage's 5 minute epoxy and a woodworking type clamp to hold it in place.
  8. Wire it up as needed, replace in dash with two screws you removed earlier.
  9. Crack open a brown bottle or heaven and admire your work (as long as you are on private property!!! Cops and beer and trucks and you is not good math)
Old May 23, 2010 | 11:16 AM
  #3803
Thank You.
Seems easy enough.
Old May 23, 2010 | 01:08 PM
  #3804
2k10HemiRam's Avatar
2k10HemiRam
Yea true I should finish removing everything myself. Didn't think about the fact they'd most likely add that into the labor charge ect...
My second thought though on it is that I'm not sure if i can get all the junk that's built up behind the badges and what not but I guess there's only one way to find out.
Old May 23, 2010 | 02:04 PM
  #3805
lastrights's Avatar
lastrights
the badges are easy grab a can of adhesive remver when you get it all off
the tailgate takes time but looks good when done
Old May 23, 2010 | 02:57 PM
  #3806
2k10HemiRam
I guess I should have been more specific but I was talking about the dirt, pollen, and even algae looking junk that's built up behind them that I can even remove with a pressure washer. I guess there's really only one way to find out and even if I can't remove that stuff, I'm thinking of putting enough money away this month and next so that I should be able to get it in for paint at the end of June. If not then it'll wait until sometime July.
Old May 23, 2010 | 03:10 PM
  #3807
95RAM360's Avatar
95RAM360
just drove it a little bit for the first time in a week.
Tranny shifted through all the gears perfect, and i havent done the next flush or tps change yet...first up first crank, Oil PSI was around 55, so thats a good sign, she drove awesome which is a load off my back.
Just wanted to get the fluids moving around a alittle bit...i hate having vehicles sit.
heres what i still need to do:
Harmonic Balancer, Front Seal, Alignment, Another tranny flush, TPS changed, and i need to get my fuel guage working again.....
I miss my truck, i wish i could take her out for a nice ride tonight, but im not risking having something else get damaged
Old May 23, 2010 | 08:30 PM
  #3808
canada_rokzz
Got my drivers side leaf pulled out and replaced... That was no fun. One siezed bold on the bottom of the shackle. Tried a small MAP gas/oxy torch (which worked way better than 70 bux would let on) then got out the grinder and a cutting disk. Ground off the back side of the bold, and cut the front side between the shackle and the mount. that got me enough room. New one bolted up like a snap!
Started prepping the "new" diff to go in. Gonna need to replace the hard brake lines, gonna inspect the seals to insure no future problems and hopefully install it tomorrow!!! All I forgot was new wheel cylinders.... Grrrr... Gonna grab some 1 ton chevy units on Tuesday, because I remember reading on here somewhere that they are a direct fit. Tomorrow is a holiday here! Yay for Queen Victoria and her birthday!!!
Old May 23, 2010 | 09:57 PM
  #3809
mnewbolds's Avatar
mnewbolds
Recieved a gift today. New bedrail caps from LMC truck! Too bad I just bed coated the whole thing. FOR SALE i guess.
Longbed-ABS plastic-ribbed w/ stake holes.
Old May 23, 2010 | 10:00 PM
  #3810
Maori's Avatar
Maori
delete..
