Help - My Truck Won't Run
Old Sep 11, 2011 | 05:53 PM
  #121
drewactual's Avatar
drewactual
I just saw the movie transformers advertised on showtime..
A thought occurred to me...
what are the chances the ghost in your particular machine has died?
drewactual
senior vice president for the assistance of
appointed candidates for the unification of one universe
order based on the destruction of races alien to the
galaxy Milky Way, and dependency of toilet paper on
the PLANET Pluto as an nonredeemable fuel source.
Old Sep 12, 2011 | 08:37 AM
  #122
Gary-L's Avatar
Gary-L
Veteran: Navy
How can I tell if the valve body in the transmission is working? Is there any way that will affect if my truck starts or not? If I remove the catalytic converter, would that make a difference?
Old Sep 12, 2011 | 08:56 AM
  #123
redneck_ram's Avatar
redneck_ram
did you get your truck running yet vw? if not have you tried putting your truck in park and turning the key, or in neutral and turning the key? also you may want to try putting oil in your gas to lube the cylinders. give that a try and see if it starts. maybe its something simple that youre missing.
Old Sep 12, 2011 | 09:40 AM
  #124
Gary-L's Avatar
Gary-L
Veteran: Navy
This is REALLY PISSING ME OFF. I'm ready to sell this truck because no one has told me what I need to do to get this truck running!!!
Old Sep 12, 2011 | 09:42 AM
  #125
Put the spurs in 'er sides, and holler GIDDYUP!
Old Sep 12, 2011 | 09:44 AM
  #126
redneck_ram
stick something in her tail pipe and see if she does anything hahahahaha
Old Sep 12, 2011 | 01:29 PM
  #127
stangs13's Avatar
stangs13
Just dont forget to get the new (preferably bosch) O2 sensor and just stick it into the tail pipe, you got it brother!
Old Sep 15, 2011 | 10:52 PM
  #128
rczanstke's Avatar
rczanstke
I've heard our trucks will only run if you put lead additive into the tank.
But it has to be poured DIRECTLY into the tank, NOT through the filler neck.
To do this, you must cut a hole into the side of the tank.
Then you pour the lead additive into the tank.
Then you weld the hole shut.
Also, I broke one of my brake lines.
I can fix that by wrapping it with duct tape, right?
Bob
CEO of Bob & Tom's Dumpster Diving, inc.
Old Sep 16, 2011 | 02:28 AM
  #129
Mpi360's Avatar
Mpi360
Have you tried TESTING the 5 volt wire running to the Dingle Arm Modulator?
Yes/No
At work(iam a Quantum Spectrometer Technical Engineerd)we like to use the Hewlett Packard Model XJT-7560 Dual Column Gas ChronoGraph with Flame Analyzation Detector's. Excellent unit and very expensive.
JEFF S.
Head of Quantum Spec Div.
Old Sep 16, 2011 | 03:12 AM
  #130
generaljr's Avatar
generaljr
maybe if you give her some therapy, or try to find some learning wheels.
