Ram Body work
200 for a gallon of paint is a good price. i paid 300 for a quart and a half when i had to repaint the hood and fenders on my 01 ram, ram vs. bambi wasn't pretty. when you do your final sanding use 600 grit ppg is a good paint but will show 320 400 saning marks. make sure you use a surface prep cleaner before putting body fill on so the metal is as clean as possible. i just finished a friends 97 ram 2500 v10 ext cab long box. one gallon was just enough so you should be okay with one gallon
I totally agree...if used right bondo works fine to fix small imperfections... the problem is amateurs like myself rarely use it that way.... And thats why it gets a bad rap.. Another reason, there's a defect on the hood of my vette were I used glazing putty and didnt let it cure enough before priming and painting... like a week after painting it showed up and reared its ulgy face...
For a gallon, $196 just seems like a LOT of money. But then again, mixing 1:1 with reducer at $26, makes 2 gallons of paint for $222. or only $111 per gallon. Should be more than enough to do the entire Ram and enough to touch up a few places on the Yota.
Also will be using a 2K primer which is a high build, and then an epoxy primer for adhesion promotion (in black) and to cover the gray primer before i spray base. I will sand with 1500 - so no scratches. Will use 2000 grit to color sand before buffing.
Worked on a few more dents this afternoon and after sanding, most were small bondo spots about 3/8" diameter and oh so thin! May tackle cutting of rear panels tomorrow but did not feel like pulling the bumper today.
Did a little work on Ram today. Sanded out the bondo from yesterday, especially the large dent I pulled at the rear of the cab. (forgot to take a photo before it got dark).
But then I found 4 small dents on the hood that I had not noticed so I sanded them to get ready to fill.
Don’t know how freezing temperature may effect paint and clear, I usually store these in an old ice chest during the winter. A freeze was forecast for today, but it was mid 50’s…
Then decided to install new gauge pod, which was black so I pulled off both a pillar covers. To make sure color matched I wanted to prime all pieces with a light primer.
Washing pieces to remove any dust or oily reside.
Primer sprayed on:
Spraying pod:
Pod and a pillar covers finished:
Going to drop rear bumper tomorrow if weather holds so I can cut out beat up lower panels and weld new ones in place.
Primer sprayed on:
Spraying pod:
I already snapped it in and out a couple of times with the "practice pillar" - it helps out a bunch as I am not as worried about breaking a clip off while going in and out with it (thanks!). Existing pillar cover is pretty brittle so I was careful drilling a hole for the wires. Also using velcro instead of screws due to being afraid plastic will crack. Between the velcro and the lip on door seal, it appears to hold very firm. Going to give it a day or so for paint to cure before gluing velcro on pillar. Probably did not need to paint the existing pillar, but wanted to be sure in case an edge showed.....one of those retentive things I suppose.
Pulled the wiring from the pillar to down below the dash. Haven't decided where to penetrate into engine bay yet. Will probably do this when I figure relays for headlights and trailer brake controller.
It is 39 and rainy today, so that pretty much kills the idea of dropping bumper outside and cutting panels out. Something about mig welding in the rain is not appealing......guess I'll watch football instead!
up in canada we get hammered hard on paint cost. i totally agree on ppg product more hype than anything. i was told that the only differnce between omni and ppg was the voc rating not sure how correct that info is. thats going to be a sharp looking truck when your done. are you putting the bumper back on or a roll pan? when your doing the final blocking guide coat works good to find any low spots
