E Fan and other work
Old May 14, 2012 | 09:12 PM
  #91
gdstock's Avatar
gdstock
I just talked to John Mercedes (well, e-mail abck and forth) and he said that it is not necessary. I did notice some of the additives mentioned not to use with cats. I picked up a Lucas Zinc additive to use to soak the rockers in, but will use my regular oil. John even said soaking was not necessary, but I think I will do it just to make sure they do not start out dry.
I think I will soak in oil with this Lucas additive:
And here is the fude block I added. The two wires at the bottom are for the e-fans and the wires at the top are for electric trailer brakes and KO power for Glow Shift gauges. This eliminates the in line fuses from gathering and multiplying like rabbits around the PDC. (forgive the movement in the photo - pain meds....make me shake like a dog and a peach seed...)
Old May 14, 2012 | 11:10 PM
  #92
Originally Posted by 2x1972
I love how you just assume that any oil put into any of our motors will exit through the catalytic converter
Sad but true eh?
Old May 14, 2012 | 11:19 PM
  #93
gdstock's Avatar
gdstock
Sad but true eh?
Unless you want to count the rear seal, oil pan, or valve cover gaskets.....
The threads over the weekend caused me to check the bolts on valve covers...a number of them were loose. I have some oil on the underside, but not enought to drip. It will get new gaskets when I put the rockers in, and I boght pan gaskets months ago. After new valve cover gaskets and washing the underside of engine I will deterine whether or not I need to drop the pan after a couple thousand miles.
Old May 15, 2012 | 01:12 AM
  #94
Wh1t3NuKle's Avatar
Wh1t3NuKle
Fuse box, me likes. Pick that up from where big guy?
Old May 15, 2012 | 02:56 AM
  #95
milesdude1's Avatar
milesdude1
Where did you order your HS's from?
Old May 15, 2012 | 10:14 AM
  #96
Wh1t3NuKle's Avatar
Wh1t3NuKle
Go back a few pages as he states that and even puts the website url.
Old May 15, 2012 | 11:08 AM
  #97
gdstock's Avatar
gdstock
Fuse box - Autozone - Bussman BP-15600-16-2, ATC 30A, 6ct. It was $10.49. Higher than I could have gotten - but I wanted it now....
And HS Rockers - http://southeastrt.com/
Old May 15, 2012 | 01:36 PM
  #98
zman17's Avatar
zman17
Retired Moderator - RIP
The VC bolts coming loose are common. I'm sure just tightening them down will cure that.
Oh, and I used this when installing the rockers.
Old May 15, 2012 | 05:21 PM
  #99
Wombat Ranger's Avatar
Wombat Ranger
^^ Your Subi?
Old May 15, 2012 | 05:26 PM
  #100
gdstock's Avatar
gdstock
Only work today (numbing wearing off). Installed control wiring for e-fans....
