E Fan and other work
Old May 28, 2012 | 09:49 PM
  #161
nate_9ers's Avatar
nate_9ers
Show truck quality here!
  #162
crazzywolfie's Avatar
crazzywolfie
looks good. i don't think i could have waited for the paint to dry. i would have fire up the truck with the valve covers off.
Old May 28, 2012 | 10:37 PM
  #163
gdstock's Avatar
gdstock
Originally Posted by 2x1972
That blue theme is gonna be killer... Them valve covers look awesome! Why din't you take the PCV out when you painted them?
I took the PCV out, but left the rubber grommets. The grey PCV, black grommet, and blue VC? Thought blue gromment would look better. The snout that is there is the stub that connects to hose going back into CAI. Damn thing was tight and afraid I would break it - with no one open today...
Now I am thinking about the blue aluminum billet fuel rails!
Don't know about show quality, but a certainly a lot better than it was when I got it!
Old May 28, 2012 | 11:40 PM
  #164
EndIsNear's Avatar
EndIsNear
You gonna upgrade injectors too if you do that?
Old May 28, 2012 | 11:50 PM
  #165
gdstock's Avatar
gdstock
Not at this point. No problems with current injectors so far. I have 275,000 on OEM injectors on Yota, and Ram only has 135,000. Hoping they aren't about to give up on me. Just think the billet fuel rails would dress up engine a little more.
Old May 29, 2012 | 03:03 PM
  #166
gdstock's Avatar
gdstock
I should have known taht things are moving along too easily.
Upholstery shop (Ney York) called. He only has fabric for the driver seat in GREY!
My interior is tan....
Does anyone have a truck they are parting out with tan interior that is like this:
The shop can use fabric from a rear seat or from undamaged pass side front seat.
Old May 30, 2012 | 12:17 PM
  #167
gdstock's Avatar
gdstock
OK. Now getting ready to paint stripe. Fought mosquitos (think they won) and got it masked off last night (hence low light level photo). Did not get piece on back of cab below rear window. Got to figure a way to remove and slide bed back. Not enough room to buff this area so may wait to stripe it when I can shaghai some help....
Also, when putting in rockers, it appears I forgot to put hose back on pump bypass. Fixed that (only moved truck 10 ft so no harm). Removed rad cap and saw some crap inside. I did a flush when I replace water pump and radiator some months bacvk. It appears that I need to flush again!
Old May 30, 2012 | 12:31 PM
  #168
Wow, that's pretty nasty...... What flush did you use previously?
Old May 30, 2012 | 12:37 PM
  #169
gdstock's Avatar
gdstock
Prestone I think. Got another bottle on the shelf - but may look for something else! But this may have been some crap that it was working on and is finally all clearing out. No overheating or any issues, and I haven't really driven it much. The radiator and system was pretty nasty when I got it so it may take a flush or two to get it clean.
Old May 30, 2012 | 12:45 PM
  #170
I think the prestone stuff is just a descaler...... I used it on my van, could also stand something meaner, a couple more times.... (yes, it was rather neglected as well.)
