E Fan and other work
Old May 10, 2012 | 10:12 AM
  #41
gdstock's Avatar
gdstock
Originally Posted by 2x1972
I like to keep my hardware the natural metal color, even when going with a black theme. I think it gives it a nice accent. Plus then it doesn't chip...
I thought about that and kept going back and forth. The good news, it's all 1/4" zinc bolts and washers. If I want to change back out it is no big issue...I have many standard bolts nuts and washers bought by the large box. Thought I would see how it looked black to begin with.
Old May 10, 2012 | 06:39 PM
  #42
gdstock's Avatar
gdstock
I received the additional carpet samples today. The one I chose (9777 Medium Beige) was not OEM color so vender wanted to make sure I was getting what I wanted. They sent me the OEM colors used by Dodge, but they still dod not look correct. I removed the cover from the driver side rear seat supprt and cut a piece of the carpet. It was protected from wear, dirt, and other stains that are so prevalent in the truck.
Comparing to the samples received today, the 9777 was still the closest to the original color.
Old May 10, 2012 | 06:42 PM
  #43
Yours still looks a bit darker..... if it was on a horizontal surface... might just be dirty. have you shampooed your carpets yet?
Old May 10, 2012 | 07:16 PM
  #44
gdstock's Avatar
gdstock
Too many stains that won't come out along with considerable wear. It is not salvagable. That piece was from under seat bracket beneath the plastic cover, so it is clean. It is slightly darker that the samples, but the 9777 looks close enough. The exposed carpet is not as dark as the long pice in the photo. Some of the stains look like bleach spots. The next challenge will be to fix the worn driver seat!
Old May 10, 2012 | 09:17 PM
  #45
gdstock's Avatar
gdstock
Tinkered with e-fan some this evening...
Ranger double header so not much Ram work...
Old May 10, 2012 | 10:19 PM
  #46
EndIsNear's Avatar
EndIsNear
Damn that looks good.
Old May 10, 2012 | 11:02 PM
  #47
gdstock's Avatar
gdstock
Thanks. I may hold off installation until after HS Rockers arrive. Don't want to scratch this up doing that work. And of course painting this I have to paint inside of engine bay. Otherwise that will look ugly. May have to dress up engine after that!
Old May 10, 2012 | 11:49 PM
  #48
EndIsNear's Avatar
EndIsNear
I love having a clean engine bay. I always detail when I detail my pickup. It runs better when I do
Old May 11, 2012 | 01:51 PM
  #49
drewactual's Avatar
drewactual
I think it's pretty evident a 'coon has pissed in his truck..
Old May 11, 2012 | 09:30 PM
  #50
gdstock's Avatar
gdstock
That explains it! I was wondering WTF! Damn coons!
I also received the side molding that was backordered from LMC today:
Also worked in installing wiring wand controls for e-fan.
o
