Wheeling a fullsize
Old Aug 9, 2014 | 01:34 PM
  #591
h3lzsn1p3r's Avatar
h3lzsn1p3r
Originally Posted by Wh1t3NuKle
Haha. My wife and she tatooed it.
Its a roller
Got it home last night. Front all done less some brake line adapters.
looks good... when is the rear getting the knife? is it going to get a 4 link or keep the leafs?
Old Aug 9, 2014 | 05:33 PM
  #592
Ham Bone's Avatar
Ham Bone
looks bad *** man. freaking awesome.
are those just struts? sorry if i missed it in an earlier post.
Old Aug 9, 2014 | 09:20 PM
  #593
Wh1t3NuKle's Avatar
Wh1t3NuKle
This week. Staying leafs. Going links requires losing the fuel tank or moving with strategery...
They are coilovers with remote reservoirs. Adjustable for spring rates, meaning you can change the springs out as well as the nitrogen pressure.
Old Aug 10, 2014 | 09:46 AM
  #594
corbo1962's Avatar
corbo1962
Absolutely Sick! Looks like you gained another inch of lift in the front. Can't wait to see a picture of it articulating. Good work WK!
Old Aug 10, 2014 | 09:53 AM
  #595
Blue Mopar01's Avatar
Blue Mopar01
I gotta say the progress on your truck is super wicked man!
Old Aug 10, 2014 | 05:14 PM
  #596
Johnn123's Avatar
Johnn123
Badass WK! Way to go!
Old Aug 10, 2014 | 06:43 PM
  #597
h3lzsn1p3r's Avatar
h3lzsn1p3r
only if going with long arms. i have seen people sacrifice the links length just to keep the tank.... the leafs in the rear would be better to keep unless air bagging it just for the towing aspect. in my opinion
Old Aug 10, 2014 | 10:55 PM
  #598
Wh1t3NuKle's Avatar
Wh1t3NuKle
Thanks guys. The front end is definitely where all the effort is and it's pleasing to have it pan out. It was setup at 2.5" above my previous ride height. When the rear is put in that will have some height to it to level out, plus the front coils will settle a bit. We'll see and cross fingers.
Long arms is the only setup with merit. Show us a ram that did what you are saying. I don't tow, which would be counterproductive to the scope of this build.
Setup at home and pulled the tried and true 231 tcase tonight.
Link to thread on the seals for input.
https://dodgeforum.com/forum/2nd-gen...case-seal.html
Old Aug 10, 2014 | 10:59 PM
  #599
Ham Bone's Avatar
Ham Bone
Dood, your truck is so sexy....
Old Aug 16, 2014 | 11:34 AM
  #600
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Rear Dana 70 is in
Thanks...it's a moving so close to the end....
So roughly 3.5 weeks to get to this point!
Sitting on both axles now. Rear came up a bit as expected b/c the aftermarket perches are about 1" taller than the ones on the Chrysler 1.25". My culdesac has a crown to it though too.
Set pinion angle to within 1*. Perches are hard tacked. Driveshaft ordered and ready Monday. Plan is to pickup, install, and drive back to have them double check the angle. If needs a change, then easy to grind off and then full burn in.
Tcase all mocked up for the above setup. Today hoping to pull out and final mount to be done.
Here is my to-do list in somewhat of an order --
Rear brake line on axle
Rear brake line feed
Rear shock mounts
Front brake lines, T junction
Grease locking hubs
Transfer Case
Mount BB to 241, RTV
Assemble shifters for 241 and BB
Front axle
Check alignment
Torque all fastners
control arms
track bar
shocks
Determine Sway Link tab location
Determine shock reservoir mounting location
Steering
Torque all TREs
Install cotter pins
Torque pitman arm
Add Tranny fluid!
Design crossmember
Diff fluid
ARB hookups
