redneck_rams 360 build thread
Old Mar 23, 2013 | 09:19 PM
  #411
woods4life's Avatar
woods4life
Could you unplug it and see if that helps?
Old Mar 23, 2013 | 09:30 PM
  #412
gdstock's Avatar
gdstock
Originally Posted by redneck_ram
no, its only the mt2500... i wonder if i swap out the pickup from the 5.2, if that would work.
also, i just remembered... there was one wire on the upstream o2 that had a portion of bare wire by the base of the sensor. would that cause a problem?
I think the pick up is the same, but don't hold me to it. If bare wire shorts on something it could cause a problem.
Old Mar 23, 2013 | 09:34 PM
  #413
crazzywolfie's Avatar
crazzywolfie
according to rockauto they both have the exact same part numbers
Old Mar 23, 2013 | 09:48 PM
  #414
redneck_ram's Avatar
redneck_ram
yes they are the exact same. i guess ill look into getting a new o2 sensor too.
damn thing is one new part after another!
Old Mar 23, 2013 | 10:43 PM
  #415
Johnn123's Avatar
Johnn123
Haha its always that way RNR! Oh well soon you will run out of parts to replace :P
Old Mar 23, 2013 | 10:47 PM
  #416
merc225hp's Avatar
merc225hp
Check and verify timing marks are still lined up, HB and Dizzy plate too rotor. Me I would loosen off the dizy turn it one way or the other with the truck running to see if it improves things find the sweet spot lock it down then reset the fuel sync, but that's me.
Old Mar 23, 2013 | 11:09 PM
  #417
gdstock's Avatar
gdstock
Great idea...and no cost. It couldn't hurt to try it!
Old Mar 24, 2013 | 08:40 AM
  #418
redneck_ram
guess ill take a video to show what its doing. it doesnt happen all the time. it runs too good to be 180 out.
Old Mar 24, 2013 | 09:59 AM
  #419
redneck_ram
well, i think i figured out the backfiring thru the TB issue....
i had to replace the crank sensor due to a ripped off wire.
i bought this one. i think that may b the issue. i remember seeing that these truck are finicky when it comes to crank sensors. i should have went to napa to get it!
Old Mar 24, 2013 | 11:18 AM
  #420
dhvaughan's Avatar
dhvaughan
^ that one from Advance has a lifetime warranty. can you camoflage the damage and warranty it?
i just don't see why a non-mopar sensor wouldn't be just as good. its just a magnet.
