Dana 60 Swap!
Old Oct 25, 2013 | 05:01 PM
  #111
Ham Bone's Avatar
Ham Bone
I'd figure something out
http://www.jegs.com/i/Cragar/260/%23...rentProductId=
What's a blemish?
Old Oct 25, 2013 | 05:27 PM
  #112
merc225hp's Avatar
merc225hp
A blemish is in most times a defect in the finish, and will not alter how the item works.
Old Oct 25, 2013 | 06:48 PM
  #113
Ham Bone's Avatar
Ham Bone
But how bad is the question
Old Oct 26, 2013 | 11:44 AM
  #114
Ham Bone's Avatar
Ham Bone
So guys, what's the trick to getting these wheel bearing off?
Old Oct 26, 2013 | 11:53 AM
  #115
Sacrificial socket, and extension. Put the socket on the bolt. Only have it threaded in about half way. Use the extension so you have enough length that you can get a good swing at it, and actually expect to hit it. use a heavier hammer than pictured to whack it good and hard a couple times. Chemicals won't hurt either.
Old Oct 26, 2013 | 11:57 AM
  #116
Ham Bone's Avatar
Ham Bone
the axle nut bolt?
Old Oct 26, 2013 | 12:01 PM
  #117
Arde's Avatar
Arde
Yep, brute force with a 3 lb. hammer.
Old Oct 26, 2013 | 12:02 PM
  #118
Arde's Avatar
Arde
spindle bolt
Old Oct 26, 2013 | 12:05 PM
  #119
Ham Bone's Avatar
Ham Bone
Man, that's a 30 dollar socket
Old Oct 26, 2013 | 12:19 PM
  #120
Arde's Avatar
Arde
Speaking of the 3 bolts on the back side, not the axle. Mine are 14mm. 12 point. As far as I know the 60's are the same.
