Ham Bone's (not so) secret thread of auto to manual swap.
Actually, that sounds perfectly reasonable. Keep the R's up if the truck is still moving, to make shifting easier, and go easier on the clutch..... and if you stop, then drop the idle down to reduce fuel consumption, or some such.
Ham Bone, did you end up finding a solution for your front driveshaft? I'm looking to do this swap on my 1500 soon, and I plan on upgrading to the same tcase you have (241). Thanks for the awesome write up!!!
The solution is to find a ds from a factory 2500 With the the same setup I have now.
Or to get the front driveshaft shortEned about an inch or two.
I have not called the shop yet though due to being really busy.
How hard is it to swap pcm's? I have a manual pcm out of my 94. Anyway my truck is done. I don't have the front ds in but both look the same anyway? I was just being lazy. I can actually stand driving it now!
I'm anxious to get some kind of a tune on this truck now. Should see some nice improvement when I get that death flash off of it. And no worries about breaking the trans now
I put my shortnend Driveshaft in yesterday. I had it cut 2 inches. Shortneded and balanaced for 100 bucks even. Works great.
4lo and first gear is pretty ridiculous. I know 1st isn't a TRUE granny gear compared to some of the old school trans. But I can get out and walk beside the truck when it's in four lo.
Oh and I use second gear as first all the time. First only goes like 10mph with my 4.10 gears. ....
