Ham Bone's (not so) secret thread of auto to manual swap.
Old Mar 15, 2015 | 03:25 PM
  #41
snowboundrmk's Avatar
snowboundrmk
Nice job and write up. Good to see the ARP flywheel bolts and the manual pcm worked for you.
Should be interesting to see how my performance pcm handles the stick tranny if I ever get this swap done.
Yeah, that's the only thing I'm worried about. I have the mopar pcm, and I don't think they make a manual one.
Old Mar 21, 2015 | 07:23 PM
  #42
snowboundrmk
What did you do for the breather hose, and do you have a picture of how you shimmed the crank sensor?
Old Mar 21, 2015 | 09:32 PM
  #43
Ham Bone's Avatar
Ham Bone
The breather hose for the transmission is just a standard 5/16 hosE with a breather cap.
No pics of crank sensor but I shimmer it with two little washers for each bolt. You want just the smallest amount of air visible between the flywheel and sensor. If it's flush it will destroy the sensor.
Old Mar 24, 2015 | 11:04 PM
  #44
snowboundrmk
Do you have a part # for the arp flywheel bolts, and where did you get the pressure plate bolts? I take it the dealership can't get them, and that's why you went with the arp bolts?
Old Apr 3, 2015 | 10:49 AM
  #45
Ham Bone's Avatar
Ham Bone
Snow
As soon as I can find my parts list I will post them all. I have almost all of the needed numbers. But I can't find the paper right now. Sorry.
Arp was just for the flywheel bolts. Pressure plate bolts were on the shelf at the dealer. They are part of a good clutch job after will.
Old May 4, 2015 | 05:36 PM
  #46
Ham Bone's Avatar
Ham Bone
Well I still can't find my parts list.....
But. If your trans didn't come with the reverse light switch you can use this part
http://m.advanceautoparts.com/mt/shop.advanceautoparts.com/p/carquest-by-bwd-four-wheel-drive-indicator-lamp-switch-s9255/5970059-P
Part number s2995
and this pigtaiL for a T56 and some other Chevy trans.
http://www.amazon.com/gp/aw/d/B00MR8Z7WY/ref=pd_aw_sbs_auto_2?refRID=1GNGT665F4DWHQE4ZN58
Also snow. I have read that you can use a manual tps to get rid of that problem I had. I have not looked into this and not sure if it's true for us gassers But I have seen it mentioned a couple times. However, it might just be a diesel thing.....
Row on!
Old May 29, 2015 | 09:33 AM
  #47
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yo, did you ever wrap this up?
How's it going?
Old May 29, 2015 | 08:56 PM
  #48
Ham Bone's Avatar
Ham Bone
Yeah got the reverse lights working. Just passed state inspection. Been driving it all the time. Shifts great, great clutch pedal. Feels like the truck came from the factory as a manual.
Also, the short throw shifter is working smooth as butter. Not a problem with that piece at all.
Nothing else to say really. Everything regarding the trans swap has been done. No problems to report.
Old May 31, 2015 | 11:17 AM
  #49
Wh1t3NuKle's Avatar
Wh1t3NuKle
Sweet buddy! Glad to hear it's doing the job. I know you've been wanting this for so long and what a relief.
What do you mean short shifter? Length?
Old May 31, 2015 | 02:05 PM
  #50
Ham Bone's Avatar
Ham Bone
The short throw shifter I got in lieu of the OEM shift tower.
700 bucks vs the 220 for the short throw.
The shifter itself is a little shorter. But its the perfect height to rest my arm on the center console and be able to change all gears comfortably.
I had another pic to show how tall it was but photbucket is being wonky.
Yeah I have been planning and wanting this swap for a long time. I have complete piece of mind to drive my truck anywhere now. And not have to worry about a high mileage auto.
Still loving the Dana 60 and suspension swap though
Maybe next is lift and big tires. Who knows.... Haha
