When i press on gas engine slows then revs up
I should have mentioned I have this scanner, I thought it was kind of a joke, i may have underestimated it,
I did the test and it went up to 77.6% I did real small increments and it responded every time I touched the gas peddle all the way to 77.6%
That *might* be a bit low for WOT, not sure on the dodges...... but, TPS is apparently working as intended, regardless of what other tests are showing.
We havin' fun yet?
Start the engine, let it idle, and watch MAP values as you slowly open the throttle. (but not real far, as you need the engine running for this one.
We havin' fun yet?
