My "Rock Solid" Ram Steering Upgrade Experience
Old Sep 16, 2012 | 11:46 AM
  #51
Won't make a difference.
You need to properly inspect all steering parts, and the track bar, and have your alignment checked, along with proper tire pressures, etc.
Old Sep 16, 2012 | 11:58 AM
  #52
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by truckmen
Thank you, David Alan,
I've just finished ordering this kit and you should see my order from Maine soon.
I hope this works.
I don't actually have a "clunk" nor play when I turn my sterring wheel but the truck is all over the road at almost all speeds. I've disconnected my tie rods and slowly turned the wheel lock to lock several time to locate any play. There is absolutely none. Furhtermore, I've carefully checked both tie rod ends before re-attachin them. Those too, were tight with no play. I wiggled the tires and rotated the rotors to see if I could observe any binding - none.
I purchased this truck with a newly replaced box and everything feels tight. This truck just does not want to steer straight. The sterring also does not want to "return" and instead wants to take off steering even harder in the direction I've turned the wheel the symptom is in both directions evenly.
Well, anyway, let's see what happnes when I install your kit in a few weeks.
Ralph M Bohm
Bucksport, Maine
Thats the steering box itself and the bushing is not going to fix that. I'm guessing the box was replaced with a rebuilt from a local parts store.
Old Sep 16, 2012 | 12:11 PM
  #53
EndIsNear's Avatar
EndIsNear
Im gonna agree with the others. I think the bushing wont satisfy your needs. Its good preventative maintenance, and it wouldn't hurt to still install the bushing. But even with good, tight steering components, these trucks just like to wander. Lots of guys are having good luck and swearing by the Red Head steering box and the Borgeson box. There's also a member here who swapped his steering to like 2002 rack and pinion steering and its much more efficient, and according to him more cost effective. Just a little ingenuity is all, and some fabrication skills.
Old Sep 16, 2012 | 01:32 PM
  #54
It's Me Patt's Avatar
It's Me Patt
I hope this works.
Ralph M Bohm
Bucksport, Maine
Besides tires (pressure/wear) & alignment, also binding or worn steering column couplers or a worn/loose steering gear..post your findings
Old Sep 16, 2012 | 05:41 PM
  #55
renardk764's Avatar
renardk764
https://dodgeforum.com/forum/2nd-gen...inion+steering
Link for the conversion. Looks interesting and might try it myself.
KenR
Old Sep 16, 2012 | 06:53 PM
  #56
UnregisteredUser's Avatar
UnregisteredUser
Mine doesn't wander at all except for a very slight bit of camber steering that's to be expected of a solid front axle 4WD. If the wind isn't blowing, my usual out on the highway is to just plop my left wrist atop the steering wheel, and occasionally make a slight adjustment for changes in road camber.
The Saginaw steering boxes like we've got are known for getting loose when the sector shaft (the doodad the pitman arm is stuck onto) gets sloppy due to worn bearings -- you cannot adjust for worn bearings and have to repair the steering box, preferably before the sector shaft motion causes excessive wear on it and the rack block which then require replacement (or remanufacturing) of the box. On my todo list is adding in one of these cool steering stabilizers. I like that idea better than upgrading the steering box because it's easier to find stock parts if something breaks during a long road trip and it's long road trips that put most of my truck's miles behind it.
Post Script: None of this is to suggest that the Rock Solid isn't necessary. The way I figure it, everyone should put that in just because it doesn't suck like the factory pieces do. My point here is that there's no reason to accept a wandering truck just because lots of guys report that their trucks wander.
Old Sep 17, 2012 | 11:09 AM
  #57
RamSteeringFix Guy's Avatar
RamSteeringFix Guy
Ralph:
Ok, saw ur order, thx.
I agree u likely have s. box issues. Tried the factory box adj procedure yet ? Careful, don't overtighten!
Also, ur a 4x4, right?
If so, I bet ur track bar is loose / worn out. Ur comment re trucks keeps steering in a given vector after finishing the turn suggests that to me.
Ck ball joint on end in DS wheel well area. If loose, consider a cost effective & simple rebuild w/ Lukes Link. Makes it greasesble & adjustable in future.
Love to hear what u find. Guys here are giving ya good advice / feedback - u just hafta weigh the options !
Best Regards, David A.
Old Sep 17, 2012 | 03:10 PM
  #58
zman17's Avatar
zman17
Originally Posted by RamSteeringFix Guy
Ralph:
Thanks for posting Dave.
Old Jun 25, 2013 | 04:12 AM
  #59
PrestonEidsmoe's Avatar
PrestonEidsmoe
I am going to ear mark this page so I can come back later. Lots of good information. Thank you guys for posting. Thank you Rock Solid for making a product that helps the Ram owners as well.
Old Jun 25, 2013 | 09:28 AM
  #60
Silver_Dodge's Avatar
Silver_Dodge
I have this kit sitting in my garage, never installed. Since I no longer have my '99, anyone interested in it?
