engine options..
Old Jan 25, 2011 | 10:00 AM
  #31
5.9 and the tuner.
Old Jan 25, 2011 | 11:34 AM
  #32
meanwhitemopar's Avatar
meanwhitemopar
all together i will have to buy the motor, freeze plugs, and im going to do a gasket set...
total about 730 dollars... vs the 630 bucks to do the 5.2 and tuner
anywhere i can get a torque converter for cheap?
Old Jan 25, 2011 | 11:35 AM
  #33
Don't go cheap on the T/C..... Check summit racing, they occasionally have some good deals.
Old Jan 25, 2011 | 11:42 AM
  #34
zman17's Avatar
zman17
Retired Moderator - RIP
You can use the Torque Converter from the 318, unless you are upgrading. In that case I would call PATC.
Old Jan 25, 2011 | 11:45 AM
  #35
meanwhitemopar
yea.. thats what im hearing.. like the TC is 175 at autozone..
Old Jan 25, 2011 | 11:47 AM
  #36
meanwhitemopar
are you sure.. cause im having people tellme i cant do that, and then a couple tellin me i can.. from the parts stores they have differant part numbers
Old Jan 25, 2011 | 11:49 AM
  #37
J415's Avatar
J415
Precision of New Hampton makes great TC's. They do stock to custom TC's. MonteC speaks highly of them. http://www.gopnh.com/
Old Jan 25, 2011 | 11:58 AM
  #38
zman17's Avatar
zman17
Last month I swapped the tranny from my 98 w/318 into my 2000 w/360 without issue, and I plow some with it. I think it's the flex plate you are talking about. Which does need to be the one for the 360.
Old Jan 25, 2011 | 12:12 PM
  #39
meanwhitemopar
ok. sounds good, ill ask around a little bit more..
Old Jan 25, 2011 | 12:38 PM
  #40
4HoNdaDODGE's Avatar
4HoNdaDODGE
i think you should get the 318 and build a monster... imo a built 318 is way tougher than a built 360 regardless of the numbers either motor puts out. dont put boost to
it boosted motors dont last.. build all motor.
