End-all Be-all plenum thread
Old Feb 8, 2012 | 11:42 AM
  #211
bwdakrt's Avatar
bwdakrt
You'll also need a new by pass hose, antifreeze, oil and filter and some RTV for the corners where the rubber gaskets meet the fiber gaskets on the side.
Old Feb 8, 2012 | 12:30 PM
  #212
Thermostat wouldn't hurt either.
Old Feb 9, 2012 | 11:30 AM
  #213
moss500berg's Avatar
moss500berg
Cool, thanks for the info!
What temp t-stat do you guys use? Ive been trying to decide between the 160 and 180, because the one i have now (OE im guessing) runs too hot for my liking
I havent checked my plenum plate yet to see if its even leaking, but i bought the kit anyways because she ate 2qts in about 4500 miles and my gas mileage sucks (13mpg 80%hwy @ 60-65mph) so im assuming my pre-cat o2 is fouled out, i plan on replacing the PCV too.
Old Feb 9, 2012 | 11:40 AM
  #214
bwdakrt's Avatar
bwdakrt
The 160* will be too cold and you'll probably get a code about taking too long for the engine to warm up. I've been running the same top of the line NAPA 180* stainless steel stat for 8 years and it's still working perfectly.
Old Feb 9, 2012 | 07:32 PM
  #215
cutthroatxxx's Avatar
cutthroatxxx
I just finished reading this thread&I do burn a little bit of oil but I just noticed the valve cover os leaking&maybe the intake for there is a spot of oil on the block by h20 pump.Ill relpace vc gasket&then see.Anyway Don't think I have spark knock but I have tinnitus so I cant hear much.Im not throwing any codes,but figured Id look in the throttle body while I was there.Now I looked in the pic thread fir the plenum but mine looked pretty clean but it did appear to be a drop or 2 of oil so what do you think?Heres a few pix but they kinda suck
Old Feb 9, 2012 | 07:46 PM
  #216
bwdakrt's Avatar
bwdakrt
That second pic tells the story of what the inside of the intake manifold should look like when you have a blown belly pan gasket. Sorry but it's time for the fix.
Old Feb 9, 2012 | 08:02 PM
  #217
cutthroatxxx
Yeah when I saw it I was hoping I wouldnt have to but I kinda Knew it.Well atleast I know where my mpgs disappeared to.Im wondering if this is also why my hvac has been acting funny?I cant seem to find a vacuum leak anywhere.Well off to watch the youtube vids on it.
Old Feb 10, 2012 | 07:54 PM
  #218
Nereaga's Avatar
Nereaga
Ordered my ebay plate just now!!! Getting the Felpro gasket kit too and ordering the manifold bolts tomorrow from dealer! pumped!
Old Feb 13, 2012 | 09:48 AM
  #219
4angrybadgers's Avatar
4angrybadgers
Did my plenum repair last week (along with the water pump, timing set, t-stat, and distributor). I bought the plate off eBay and used the plate bolts that came with it; bought a Fel-Pro gasket set, and went to the dealer for new plenum bolts. Runs fine, now I just have to get rid of a finicky air pocket that's making it overheat...
Old Feb 13, 2012 | 09:57 AM
  #220
Yeah, these trucks are a real bear to get all the air out......
