End-all Be-all plenum thread
Old Sep 21, 2012 | 09:38 AM
  #681
aofarrell2's Avatar
aofarrell2
that might be a bit much. i think you could have got away with grade 5 bolts. i was told grade 5 bolts were more than strong enough to hold my shocks in. they should be more than strong enough to hold an intake that only requires 70in-lb or whatever it is.
Yeah grade 5 would have been sufficient, however I had to get whatever bolts they had, and the only ones to match were grade 8! LOL.
Old Sep 22, 2012 | 10:42 AM
  #682
It's Me Patt's Avatar
It's Me Patt
Originally Posted by techningeer
Patt, you are wrong. Not every bolt that has a torque spec is Torque to Yield. However, all of the factory plenum bolts were TTY. Gotta get both of those correct!
yup it sux, I'm usually wrong it's just a matter of you guys pointing it out...andcI'm will never discuss TTY b's again
Old Sep 23, 2012 | 03:10 PM
  #683
gdstock's Avatar
gdstock
There is some debate on whether or not the intake bolts are TTY..... Service manual doesn't mention anything about it..... neither do any of the 'off-brand' manuals.... one would think that would be a pretty significant detail to neglect to mention.
I don't think they are TTY, I think they are just cheap assed chinese bolts... and replacing them really isn't a bad idea.... getting some good grade 5 or 8 bolts to replace them, and THOSE you could reuse.
That may very well be true HY. I replaced mine with grade 8 i think.
According to ASME and SAE, TTy bolts are NOT threaded the entire length, and are heat treated on the unthreaded portion of the shank.
All bolts have a torque spec, it's just that not all applications have a spec indicated.
ASTM A307
And grade 8 is certainly overkill, as it is not clamping a significant load in this application....but it won't hurt anything....
Old Sep 24, 2012 | 09:47 AM
  #684
aofarrell2's Avatar
aofarrell2
Great info gdstock. Yeah I know those were overkill on bolts but that was all my supplier had at the time... Just to clarify for everyone, TTY bolts aren't threaded all the way down, but not all bolts that aren't threaded down all the way are TTY.
Old Oct 11, 2012 | 08:35 AM
  #685
BlackRam_98's Avatar
BlackRam_98
I removed the intake manifold and plenum plate yesterday with the fuel rail still attached. Should I clean the injectors while in place? If so, with what and how?
I'd rather not risk cracking an injector so I'm leaving them and the rail in place.
Old Oct 11, 2012 | 11:31 AM
  #686
Wh1t3NuKle's Avatar
Wh1t3NuKle
Make sure you post pictures of your actual plenum gasket!!
https://dodgeforum.com/forum/2nd-gen...s-post-up.html
It's not absolutely necessary to pull and clean the injectors, but certainly would not hurt. If you do that, then you should get new orings that go on the injectors. Very cheap though. Actually, that's all I did was change out the orings.
Old Oct 11, 2012 | 07:13 PM
  #687
BlackRam_98
I would argue it isn't worth the risk of breaking a $50 injector if all I'd be doing is changing the o-rings.
and I will for sure post pictures of the plenum gasket, it clearly blew out at least four areas with only 106,000 miles.
Quick question, I got the hughes kit and it came with red locktite on the plenum bolts. Do I need to add blue locktite to that also? And should I add blue locktite to the intake manifold bolts at all?
Old Oct 11, 2012 | 07:28 PM
  #688
bwdakrt's Avatar
bwdakrt
Use the Blue loctite on the belly pan bolts and the manifold bolts. NEVER use the Red on any aluminum part because if you ever have to remove it you'll pull out the threads as you unscrew the bolts. Ask me how I know...lesson learned the hard way.
Old Oct 11, 2012 | 09:53 PM
  #689
BlackRam_98
The bolts CAME with red locktite on them from hughes for the aluminum plenum plate into the aluminum intake manifold...
Old Oct 12, 2012 | 09:54 AM
  #690
It's Me Patt
+1 that's hughes' doing and I don't mind, last thing I would want is for one of those bolts to work their way loose and drop in the valley!
