Pulling my tranny this evening....
Old Sep 5, 2011 | 06:08 PM
  #241
aim4squirrels's Avatar
aim4squirrels
I recommend the dana spicer life I joint. 5-790x is the part number I believe. Been a while since I did mine so check that number.
Old Sep 6, 2011 | 09:45 AM
  #242
rocky_mtn_ram's Avatar
rocky_mtn_ram
So I had to beat the daylights out of my u-joints to get them out. The front shaft where theres two u-joints in one spot, the flange where it meets the transfer case...theres some sort of pivoting ball that both flanges axis on...somehow I ripped that apart. Either that or it was already munched. Am I screwed? This is the first time I've tackled u-joints and I'm hoping this doesn't mean I need a new drive shaft.
Old Sep 6, 2011 | 09:54 AM
  #243
chadhager03's Avatar
chadhager03
If it's the front driveshaft then yes you and I are scewed. I took mine apart and it's over $100 to get it fixed. I haven't done anything to it but if you figure something out tell me!
Old Sep 6, 2011 | 12:03 PM
  #244
rocky_mtn_ram
So anyone else have a fix for this? Does that knuckle just need replaced? I suppose its dealer or salvage only, eh?
Old Sep 6, 2011 | 12:52 PM
  #245
There was another thread on this, (I believe it was chad's.....) that had links to some of the parts to rebuild the joint.
Old Sep 6, 2011 | 12:56 PM
  #246
zman17's Avatar
zman17
Retired Moderator - RIP
I suggest taking it to a driveshaft shop and let them rebuild it.
Old Sep 6, 2011 | 01:19 PM
  #247
chadhager03
Ya it was my thread, you can buy the knuckle from 4x4 parts for $110, or you can take it to a drive shaft shop and have them fix it for $125ish. I'm just going to jam it back together
Old Sep 6, 2011 | 01:28 PM
  #248
zman17's Avatar
zman17
And then when it fails in the middle of when you need it, you will be taking to a shop. And spending more money. And it's Quad4x4, I also showed you the parts were available separate.
Old Sep 6, 2011 | 01:57 PM
  #249
chadhager03
Ya I agree it's not the best idea but I only use 4wd when doing light offroading. I cant justify spending that much. I saw those parts but I need a machine press and I don't have that.
Old Sep 6, 2011 | 02:06 PM
  #250
zman17's Avatar
zman17
OK, but, you do not need a press.
