Not winning the transmission fluid leak battle....
Old 01-16-2012, 06:36 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Yep, that's be the feller. Looks like two o-rings on there? Maybe?
Seems to me, as opposed to spending some bucks on solenoids you don't really need, just find out what size the orings are, and spend less than a buck.......
  #22
Old 01-16-2012, 06:40 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Not sure you can stick any old orings in there. I'd take it apart and put the whole unit in. Unless of course you want to take it apart again if the orings you use don't work.
Got a drain plug yet?
  #23
Old 01-16-2012, 06:45 PM
HeyYou is offline
I'm thinkin' he is gonna be doin' that soon zman.
  #24
Old 01-16-2012, 06:47 PM
stewie01's Avatar
stewie01
stewie01 is offline
Thanks for the help guys, will just install new unit, I DON'T wanna have to do this again. And no drain plug yet, but it will...
  #25
Old 01-16-2012, 06:53 PM
zman17's Avatar
zman17
zman17 is offline
Well if your going to order the solenoids, then order the drain plug too. Most parts stores have them in stock, just not the B&M plug. Which I highly recommend over any others.
  #26
Old 01-16-2012, 07:02 PM
stewie01's Avatar
stewie01
stewie01 is offline
To be perfectly honest, I'm thinking about calling some of the transmission shops around and seeing how much they'll charge to do it.
  #27
Old 01-16-2012, 07:08 PM
HeyYou is offline
But, you have gotten so Good at dropping that pan......
  #28
Old 01-16-2012, 07:13 PM
zman17's Avatar
zman17
zman17 is offline
LOL. It's not that hard to do, and you don't have to drop the VB.
  #29
Old 01-16-2012, 07:20 PM
stewie01's Avatar
stewie01
stewie01 is offline
Hey, a man's gotta be good a something right? If it's dropping a transmission pan well.....
Don't have to drop the valve body? You've just renewed my interest in doing this myself.
  #30
Old 01-16-2012, 07:25 PM
zman17's Avatar
zman17
zman17 is offline
You can get to the screw and replace the harness/solenoid assembly by removing a plate with a spring inside, on the side of the VB. Don't know what that plate it's called. Then just use a very thin putty knife to hold the spring in and replace that plate.
Quick Reply: Not winning the transmission fluid leak battle....
