Not winning the transmission fluid leak battle....
Old 01-28-2012, 07:58 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,236 Likes on 2,985 Posts
Someone has been in there before?
That IS strange...... I really don't think they can escape on their own.
  #52
Old 01-28-2012, 08:41 PM
stewie01's Avatar
stewie01
stewie01 is offline
The previous owner had the transmission rebuilt, I'm not sure what all they did, if it was a full out rebuild or just a few small things, I think it was a full rebuild, anyway...
My THEORY, when it was rebuilt the shop didn't bother to replace the tcc/od solenoid assembly, and somehow before the rebuild the O rings either vanished or rotted away, I dunno....
There is no way they can get out the top. It's mind boggling....
  #53
Old 01-28-2012, 10:24 PM
gdstock's Avatar
gdstock
gdstock is offline
Hey, glad you got it fixed.... Did you drop the VB? The hole for the screw at the connector screws into the top of VB.
  #54
Old 01-29-2012, 07:21 AM
stewie01's Avatar
stewie01
stewie01 is offline
Nope, didn't have to drop the valve body. This is a picture I found, may not be exactly the same as the 46RE, but the part we moved is the same and marked by arrows.
Remove the little plate then a spring falls out and when you least expect it a little cup looking like thingy falls out. Oh, when you take that piece (name?) off a spring shoots out the side at you....
The hole for the screw is on the top of that piece.
It's slightly more work getting the rest of the assembly out.
  #55
Old 01-29-2012, 08:25 AM
stewie01's Avatar
stewie01
stewie01 is offline
Also, to keep the red paint scheme going we painted the transmission pan red, looks good, will try to get a photo later when it warms up a little.
Quick Reply: Not winning the transmission fluid leak battle....
