Tv cable & accelerator cable adjustments
Hey everyone, I have a 2000 dodge ram sport 4x4. Apparently the tv cable and accelerator cable are both common issues. I fixed the accelerator cable already, but the tv line is not adjusting properly. I believe the black piece connecting to the throttle body lever is broken. Shouldn't the cable be seated at the *** end of this piece? closest towards the front of the truck? Mine is seated on the side closest to the firewall.. so when i open the throttle all the black piece does is slide along the cable, not pulling the cable tight as it should. I am having hard shifting in 2nd and 3rd gear, it would be great if someone could clarify my issue. Thanks!
Harrison
Harrison
There is definitely a lot of slack.. if i open the throttle lever all the way (which is beyond full throttle) it barely tightens. Should the cable be seated at the end of the clip/connector? I think if it was the cable would be tight. Right now its just "floating" around somewhere in the connector.
Hope this works. My phone and links dont like eachother.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Trending Topics
the location is on the driver's side of the tranny, right by an electrical plug. the cable sits on a rod connected to the valve body along with the shifter cable. This thing is a PITA to take off the rod because the bolt likes to rust and it is at a horrible angle to get a wrench or socket on. Hopefully it can be adjusted without having to be taken off the rod...
*edit
I believe there is also a spring hooked to it as well...it shouldnt be hard to locate
*edit
