Rearend...2nd to 3rd Gen. question...
Old Jan 11, 2014 | 01:36 PM
  #31
IFD31's Avatar
IFD31
guess that is what I am trying to determine...if i repaired what i have best route would be something like a detroit locker, yukon locking diff or something with the whole new carrier and gears but my concern with that is since it looks like the pinion bearing exploded, i drove it a ways back to civilization in 4wd dont want to do all that if the pinion nose of the housing is damaged, oblongated or something and i will never get it sealed. hearing mixed opinions
Old Jan 11, 2014 | 02:57 PM
  #32
merc225hp's Avatar
merc225hp
Have you given any thoughts to installing a Dana 60 rear diff? Like HeyYou posted cheaper to find another diff but instead of a 9.25 see if there are any 60's floating around you for sale cheap. You will have better luck finding one of those (Dana 60) with the 4.10 ratio than a 9.25 with 4.10's. Yes you would need rim's they can be found used as well, spring perches are cheap like $12 for a pair and a rear ds or your's shortened.
Old Jan 11, 2014 | 04:00 PM
  #33
IFD31's Avatar
IFD31
trying to look at all options right now...not finding alot availble...not sure what will swap in, am runnning 17" wheels with 35" tires so think that would remove some issues. also dont have a huge pile of money right now plays in, just want to get the truck back up and running as soon as i can...lifes had alot of ****ty things lately so that would help
Old Jan 11, 2014 | 04:02 PM
  #34
IFD31's Avatar
IFD31
did find a guy that has the entire drivetrain from a 96 available, trying to find out what ratio it has
Old Jan 11, 2014 | 04:04 PM
  #35
Cheapest is going to be finding a used rear that is a direct swap. (same gear ratio) Next would be a D60, (surprisingly enough), most expensive would be rebuilding what you have......
Old Jan 11, 2014 | 04:10 PM
  #36
Ham Bone's Avatar
Ham Bone
Like merc said, 9.25 with 4.10s are rare as shat.
That ratio is much more available in 2500s. AKA dana 60s. Nice upgrade too.
Old Jan 11, 2014 | 04:19 PM
  #37
merc225hp's Avatar
merc225hp
The last part of the bom number for a Dana 60 will be
-1 = 3.55 ratio
-2 = 4.10 ratio
Old Jan 11, 2014 | 04:21 PM
  #38
Need to verify that the gears are indeed 4.10's.... on the first page, he was told that the front was a D60, which its not..... so, maybe the line he was given about the gears wasn't exactly accurate either.....
If the truck is an ORE (didn't notice that anywhere in the thread...), well, that's altogether a different kettle of fish.
Old Jan 11, 2014 | 04:23 PM
  #39
Ham Bone's Avatar
Ham Bone
OP your truck is an 01 correct? Pre 00 axles will be a coupler inches shorter than what yours came with.
Not sure how much it will affect....
Old Jan 11, 2014 | 04:34 PM
  #40
merc225hp's Avatar
merc225hp
Yep ok op can you post up the string of numbers that are stamped on the side of the ring gear. This will help us tell you what ratio was in the back anyway.
