Minimum fuel pressure
Old Apr 14, 2018 | 12:37 PM
  #31
beau680's Avatar
beau680
Ok didn’t know that I will take one in the driveway later today.
As far as the cat goes I had just had it gutted at my local shop it was starting to make noise. Would a thermal gauge help us at all if there is no cat?. For the rear o2 sensor I did do that little trick with the non fouler plugs on the rear so it is actually out Of the exhaust path. Was that a bad idea?
I did it because the research I had done said it would Keep my truck from running so rich an keep the cel off
Old Apr 14, 2018 | 01:28 PM
  #32
true blue's Avatar
true blue
AAAHHAA!!!, that explains the downstream O2 sensor readings. No, no therm needed. Get back with constant load numbers idle/1500/2500 RPM.
Old Apr 15, 2018 | 07:19 PM
  #33
beau680's Avatar
beau680
Old Apr 15, 2018 | 07:27 PM
  #34
beau680's Avatar
beau680
i notice around frame 15 upwards of 3000 rpms on the first photo the st ftrm is around -10 but in the second photo around the same rpm the st ftrm is around- 3. does that tell us anything?
Old Apr 15, 2018 | 07:55 PM
  #35
numbers are too small for me to read on the laptop.... I'll have a bigger screen tomorrow afternoon..... (In Florida at the moment, fly home tomorrow.)
Old Apr 16, 2018 | 08:10 AM
  #36
true blue's Avatar
true blue
my computer won't download the image for some reason n my old eyes cant read thes printouts. Plz resend. With that in mind, no, -10 isn't terrible on a used engine and an old vehicle with food in the gas. The good thing of note is that it went towards "0" n not higher.
Old Apr 16, 2018 | 11:17 AM
  #37
beau680's Avatar
beau680
Weird both images didn’t load either. I loaded 2 of them
Old Apr 17, 2018 | 09:49 AM
  #38
true blue's Avatar
true blue
I'm lost here, what's the problem with your having again? Bad idle...is it still bad? Those numbers look like a pretty healthy engine n your sensors seem to be saying...I'm feelin' the love. The timing advance seems to be stuck on 40 at high RPMs, but with snapshots instead of live stream data, I don't think it means anything.
Old Apr 17, 2018 | 11:16 AM
  #39
beau680's Avatar
beau680
Yes that was the problem truck seem to be running great now. I really just wanted confirmation that someone couldn’t see any more issues with that data. As I don’t necessarily know what I’m looking at, it looks like a pile of numbers. lol.
I really appreciate your help
Old Apr 18, 2018 | 07:32 AM
  #40
true blue's Avatar
true blue
If I knew how to stream vid onto this site...to be fair, I'm too lazy to figgur it out, however my numbers look essentially like yours. Probably a bad or dirty connector?!? A famous philosopher once stated...don't werry, be happy, especially if your munbers are good, mon!
