Steering wheel off center
Old 05-08-2018, 11:22 PM
97RamSS/T's Avatar
97RamSS/T
97RamSS/T is offline
Default Steering wheel off center
I have a 94 Ram 1500, RWD, Long bed, 5.2 L., Automatic.
Due to some kind of repair by the previous owner, the steering wheel is off center by about 15 degrees. I can't see my gauges because of this and it drives my completely insane. I have searched this site and YouTube but all the references about this issue cover the 4x4, or some model other than mine. Could someone please post me a link or something? It can't be too difficult but I'm somewhat new to Dodge so I want the most accurate information I can get. Thanks all!
Old 05-08-2018, 11:45 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
There should be some alignment in the tie rods but what may have happened is they replaced the pitman arm and didn't put it in the correct key way. If the steering wheel was turned at all they may have mounted it crooked. It does have a notch but the wheel has to be secured when replacing either steering gear or pitman arm. Get under it and see what you adjust. The pitman arm should be basically in line with the frame. If it is way off to one side but the wheels are straight, that may the issue.
Old 05-09-2018, 10:20 PM
2bit's Avatar
2bit
2bit is offline
There is a sleeve with 2 clamps on the link between the steering box and tie rods. Loosen the clamps and adjust it until your wheel is straight, then tighten the clamps again. If you change the one on the tie rods, it will change your toe in.
Old 05-10-2018, 01:38 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
He has a 2wd. Different set up.
Old 05-10-2018, 07:51 PM
2bit's Avatar
2bit
2bit is offline
I forgot the steering was different. LOL. Must be an adjusting sleeve somewhere?
Old 05-10-2018, 08:12 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
And actually, with the Y steering, you're not supposed to adjust the sleeve on the drag link as it WILL change toe. There is supposed to be a bar between the clamps preventing this because due to the design of the Y, any change to the drag link also changes the right wheel. Mine was messed up for years by a stupid shop that ripped off the warning bar and just turned that clamp. I was clueless then. The T steering is super easy though.
Old 05-15-2018, 01:54 PM
97RamSS/T's Avatar
97RamSS/T
I still have no idea how to correct this.
Old 05-15-2018, 03:08 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,393 Likes on 3,133 Posts
Take it in for an alignment. Part of the job is centering the steering.
Old 05-15-2018, 04:37 PM
97RamSS/T's Avatar
97RamSS/T
Wasn't aware of that. Excellent idea! Thanks!!
Old 05-15-2018, 11:59 PM
2bit's Avatar
2bit
2bit is offline
You would have to move the pitman arm a tooth or adjust the tie rods until the wheel is centered and the toe in is correct. I would think the pitman arm is where it should be, or has the steering box been replaced? I would adjust the tie rods.
Quick Reply: Steering wheel off center
