idle loops
Old Jun 16, 2018 | 12:25 PM
  #21
Eman2004's Avatar
Eman2004
Ok I will check, do you guys have a pin out of the PCM? I could see if it is open or shorted
Old Jun 16, 2018 | 12:27 PM
  #22
If it runs at all, its going to be an intermittent at best...... You can download a service manual for your truck from here.
Old Jun 16, 2018 | 12:38 PM
  #23
racefan41's Avatar
racefan41
Are you sure its getting a strong spark (bright blue/white)?
And are the sparks consistent without missing ? I would pull one plug at a time, hook it back to the plug wire, and watch them fire. Were all of your plugs black like your picture showed?
Old Jun 16, 2018 | 01:26 PM
  #24
Eman2004's Avatar
Eman2004
Yea all of them are black
Old Jun 16, 2018 | 02:15 PM
  #25
Eman2004's Avatar
Eman2004
The spark looks strong, but it’s orange...does that matter?
Old Jun 16, 2018 | 02:29 PM
  #26
racefan41's Avatar
racefan41
It really should look blue/white. test your ignition coil and see if it's any good
Did you disconnect your battery and reset the pcm after you put new sensors in?
I would take the coil inside and let it cool down to room temp before you test it too
Old Jun 16, 2018 | 02:47 PM
  #27
Eman2004's Avatar
Eman2004
Ok, I bought a new coil, but I have rest the PCM about 20 times now, still no avail. I’ll try the new coil, but I’lo be intrigued if it actually fixed the P1391
Old Jun 16, 2018 | 02:59 PM
  #28
racefan41's Avatar
racefan41
i'm not thinking the coil would fix the code, but i'm wondering if you have more than one issue going on. I've heard bad cam/crank sensors can burn up a coil.
Old Jun 16, 2018 | 03:14 PM
  #29
Eman2004's Avatar
Eman2004
Could my distributor be bad? I picked up one from the junk yard, but I heard you have to do a fuel resync
Old Jun 16, 2018 | 05:26 PM
  #30
Well, the code you are getting is for either cam, or crank sensor...... I think there is a different code for fuel sync, but, not 100% sure on that...... Wouldn't hurt to have it checked.
