idle loops
Old Jun 28, 2018 | 01:43 PM
  #51
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Eman2004
Do you guys know if the Fuel Sync will cause this problem?
It might. Timing being off because of the chain could cause this to. It's honestly hard to say without being there in person.
Old Jun 29, 2018 | 08:55 AM
  #52
Eman2004's Avatar
Eman2004
Default Where is it supposed to point?
Here is TDC, but should it be on the notch or the V8
Old Jun 29, 2018 | 09:05 AM
  #53
Eman2004's Avatar
Eman2004
Default The distributor looks off,
Old Jun 29, 2018 | 02:27 PM
  #54
2bit's Avatar
2bit
The notch aligns with TDC like you have it. If you came to it slowly and stopped, rotate it backwards until the rotor starts to move, then read the degrees next to the TDC mark.
Old Jun 29, 2018 | 05:43 PM
  #55
Eman2004's Avatar
Eman2004
Default How did this happen?
Old Jun 29, 2018 | 06:13 PM
  #56
30 degrees??? Wow. Time for a new timing set methinks.
Old Jun 30, 2018 | 12:06 AM
  #57
2bit's Avatar
2bit
The rotor moved some from this first picture, so it's not 30 degrees but surely needs replacing!
Old Jun 30, 2018 | 09:02 AM
  #58
Eman2004's Avatar
Eman2004
Default I
in order for the distributor to point at cylinder on the crank has to be at 30 degrees. When the crank is at TDC you can see the rotor is off
Old Jun 30, 2018 | 09:05 AM
  #59
Turn the crank the other direction, see how far you have to turn it, before the rotor starts moving. (probably requires two people.)
Old Jun 30, 2018 | 10:26 AM
  #60
2bit's Avatar
2bit
Yes, do this ^^^^^^. Maybe it's loose enough it jumped a tooth?
