Broken Axle Shaft Stuck In Spider Gear
Old 03-26-2019, 11:16 PM
WadeLyman's Avatar
WadeLyman
WadeLyman is offline
Default Broken Axle Shaft Stuck In Spider Gear
1999 2500 5.9L Cummins Automatic, everything stock. In need of some help, so Front driver side axle snapped just distal to the splines, due to the way it snapped it shoved the broken end hard into the spider gear. Anyway I am unable to remove the 5 inches of broken shaft from the spider gear. I am able to remove the shaft on the other side and spider gears without a problem, just stuck on drivers side spider gear. Any advice or ideas would be greatly appreciated, thanks.
Old 03-26-2019, 11:36 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
How in the heck did that happen?? Can you pry it out?
Old 03-26-2019, 11:39 PM
2bit's Avatar
2bit
2bit is offline
Pull the other axle and then remove the spider gears, or once you remove the cross shaft, you could put a socket between the axle shafts and give it a tap with a mall after putting the nut on the stub shaft. Once you take the other axle shaft out, the carrier would probably come out also as long as the broken piece isn't very long. I'd try taking the spider gears out first if it was me.
Old 03-27-2019, 03:30 PM
WadeLyman's Avatar
WadeLyman
Thanks 2bit !, I ended up using a 1inch metal rod and hammered the broken off end out of the spider gear, worked smooth. Spider gear is screwed up from the broken shaft, sigh...
Old 03-27-2019, 03:34 PM
WadeLyman's Avatar
WadeLyman
Lol got it really stuck in the mud.
Old 03-27-2019, 05:48 PM
MoparFanatic21
That had to be weak to begin with as they don't normally break there
Old 03-29-2019, 02:07 PM
2bit's Avatar
2bit
2bit is offline
The pipe was much better, I just didn't know what you could afford or had access to. I was certain you'd need to check for more damage. LOL. I'm glad you got it out. There's a seal for the axle shaft that I assume got destroyed. You'll need to remove the carrier to change it.
Old 03-29-2019, 04:37 PM
MoparFanatic21
He can buy an external seal that goes by the axle C
Old 03-29-2019, 06:59 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,197 Likes on 2,949 Posts
Those are just dust seals though, aren't they? I don't think there is a 'clean' enough surface for an actual oil seal to seal against.
Old 03-29-2019, 08:01 PM
MoparFanatic21
Yukon makes the actual seals that go on the outside. They make them for the 60
Quick Reply: Broken Axle Shaft Stuck In Spider Gear
