46re trans issues?
Old Feb 16, 2020 | 05:04 PM
  #51
It will go one of two ways. Incredibly easy, or darn near impossible...... Give it a shot, see what happens.
Old Feb 16, 2020 | 05:11 PM
  #52
Sheldon Fuller's Avatar
Sheldon Fuller
well... all I know is,, the last time I did this... the parking lever ended up messing up my valve body by putting it on so I’m scared tbh
Old Feb 16, 2020 | 05:13 PM
  #53
Can you pull the rod out, while you install the o/d unit? Then put it back later?
Old Feb 16, 2020 | 05:14 PM
  #54
Sheldon Fuller
yea but that’s also a pia cause you gotta drop the entire valve body and all the fluid with it :/
Old Feb 16, 2020 | 05:16 PM
  #55
I suspect a fair bit of the fluid is already out of it......
Old Feb 16, 2020 | 05:17 PM
  #56
Sheldon Fuller
believe it or not it didn’t damage the actual internal of the od unit. It only broke the bolt holes the fluid level is good in trans
Old Feb 16, 2020 | 05:23 PM
  #57
I wonder if something else is going on there, that we are missing....... T-case should not try and shift itself..... Wonder if the snap-ring has been missing for a while. No way to know now though. Or if there is something odd going on, further down the driveline.
Old Feb 16, 2020 | 05:33 PM
  #58
Sheldon Fuller
what else could be messed up?
Old Feb 16, 2020 | 10:16 PM
  #59
Sheldon Fuller
ok so I’ll be fixing my truck tomorrow... got all parts.... but... I messed around with THREE other dodges today as well... and they all have that slight play in them... which I thought might fix my problem... but it doesn’t.... so what in gods green earth would cause this to happen? Tv cable was readjusted. It won’t downshift worth a damn. It upshiftd just wont down shift.. might be a dumb question but could it maybe be something simple like adjusting the bands???
Old Feb 17, 2020 | 09:06 AM
  #60
Gotta be a sticking valve, or clogged port...... or some other mystery part that we are missing.
