HHR Fan Installed
Old Sep 3, 2010 | 12:07 PM
  #91
ozone45212's Avatar
ozone45212
Default Its here!!!
OK, got the fan. I am going today to get controller and connectors. I havent seen how much wire is with the controller yet. Newmexico, you have the setup im gonna use, what size wire do I need? I have a bunch of 14ga. primary wire left over from my air horn install, looks like its the same size...
Old Sep 3, 2010 | 07:21 PM
  #92
Altair's Avatar
Altair
Dak attack!
http://www.rowand.net/shop/tech/wirecapacitychart.htm
Check the amperage draw on the fan, I would go with at least what that chart says or a size larger to be on the safe size.
Old Sep 3, 2010 | 08:55 PM
  #93
Blown287's Avatar
Blown287
14 should be good to go.
Old Sep 4, 2010 | 11:25 AM
  #94
newmexicoram's Avatar
newmexicoram
Default HHR Fan
You will not need anything!! There is enough wire in the kit for everything.
Old Sep 4, 2010 | 11:40 AM
  #95
ozone45212's Avatar
ozone45212
Red face one more question B4 install...
One more question. After I take the stock fan off, is their anything there to keep the pulley on? Do I have to put a nut in its place? Hopefully you can answer this soon, I want to do this today...
Old Sep 4, 2010 | 04:14 PM
  #96
Blown287's Avatar
Blown287
Nope, once the fan is removed from the water pump you can leave the bolt as it is. You don't have to put anything on it.
Old Sep 5, 2010 | 07:32 AM
  #97
WTEBOY703's Avatar
WTEBOY703
too easy
Old Sep 5, 2010 | 09:23 AM
  #98
lmrjason's Avatar
lmrjason
shot out of a cannon... do yall think its possible to hook up the wire that turns the a/c on for the fan to the button inside the cab thats turns the a/c on?
Old Sep 5, 2010 | 10:10 AM
  #99
WTEBOY703's Avatar
WTEBOY703
if blown can do what he has done to his truck...anything is possible! shoot bet we could build a dakota to fly! We have Trucky he could get us a Jet Engine and help us mod some wings and we be cruisin at 30 thousand feet!
Old Sep 6, 2010 | 01:06 AM
  #100
ozone45212's Avatar
ozone45212
Wink One or two more ?? (Just wanna be sure :)
[quote=Blown287;2196105]Today the temp was 90 degrees and I drove approx. 40 miles of driving using both the highway and stop light traffic. I made several WOT runs at full boost and the engine temp never got above 180. One thing I noticed, it took the truck a little longer to warm up than normal.
Blown, is the engine temp the coolant temp? (I am monitoring with a data logger.)
Seems like setting still at idle it lets the temp climb pretty good, and its pretty cool outside tonight... But, I will say it feels like it moves a lot more air than the clutch fan. Blown, have you thought about fabbing up a shroud that will direct the air better like the stock shroud does? If I can, at some point I would like to get an extra shroud and cut it up for this. BTW, in order to get it to fit good on the 3.7 I had to cut the upper right corner out of the fan (left if sitting in the driver seat) to get it to fit up where I wanted it around the rad. hose. I ran the bolts up through the fan and screwed them into the existing square nuts and tightened extra nuts on top to secure them. Bottom is zipped until I can figure something else out.
One more question, I ran the temp sensor in through the front of the rad. until it stopped. it should not go completely through the radiator should it?
(I shoved it through the protective screen then into the radiator fins.)
Sorry for all the ??? but I am really att. to this truck!
