HHR Fan Installed
Old Aug 26, 2010 | 01:20 PM
  #71
Blown287's Avatar
Blown287
Originally Posted by Blown287
Fan Info
Part number: 15817306
OEM number: GM3115200
CFM: 3,000
From my original post, its part number 15817306 for both the 2.2 and 2.4.
Old Aug 26, 2010 | 04:24 PM
  #72
donkeypunch's Avatar
donkeypunch
King Jackass
I just ordered my HHR fan and Spal controller yesterday. I'm stoked!
Old Aug 26, 2010 | 04:54 PM
  #73
Blown287's Avatar
Blown287
That is good news. I've been super impressed with mine, so much, its hard to believe its a Chevy product, lol.
Old Aug 26, 2010 | 05:51 PM
  #74
sullysdetailing's Avatar
sullysdetailing
My next mods are going to be Tranny Temp Gauge and E-Fan
Old Aug 27, 2010 | 12:49 AM
  #75
ozone45212's Avatar
ozone45212
Question
Blown, I have to ask, with all the $$$ youve spent on your truck, wouldnt you have been pushing more ponies (301hp in your video) with an engine swap?
Old Aug 27, 2010 | 01:00 AM
  #76
Blown287's Avatar
Blown287
Well, it really all depends on how you look at it. That dyno is really old and my only performance mod was the supercharger, lol. 301 hp at the wheels on a setup than nets 170 hp (what a stock 05 4.7L averages) at the wheels is a really good gain. I really need to get back to the dyno but I keep finding new stuff to play with. Its coming, Trucky and I are looking into splitting a dyno day one day next month.
Look at the stock Dyno #'s like this.
05 Dakota 4.7L RWHP 170
07 R/T Magnum RWHP 265.5 hp
07 Hemi Ram RHWP 250
Mods since the 301 RWHP dyno.
224 Turbo Grind Cams
ASP 3.25" Pulley
69mm Fastman Throttle Body
High Load Beehive Springs
4.10 Gears
Edge 3000 stall
Alcohol Injection
True Dual Exhaust
Solid Tranny Mounts
Engine Torque Dampers
Efan/Controller
Auburn LSD (Install will be next week)
I could have done an engine swap, but I elected to build the 4.7L to see how far I could push it. I pull down over 12psi of boost every WOT run, try that with a Hemi, lol.
Old Aug 29, 2010 | 03:26 AM
  #77
ozone45212's Avatar
ozone45212
Wink
yea, ok, I see what yer going for!
Old Aug 29, 2010 | 03:42 AM
  #78
ozone45212's Avatar
ozone45212
Talking Question for Blown and Newmexico
OK, ordered my efan today. Blown, hopefully this has wiring instructions, if not, ill probably need some help. Same to you on the Autozone torqflo Newmexico! (BTW, it was a different seller Blown, Vppartswarehouse. This one had a lifetime warrenty, cost me $49+10/shipping.
Thanks in advance for the help! Cant wait to go back to the track now! Since last run I removed about 100lbs of weight, did the power wire, and modified my CAI for better air flow...
Old Aug 29, 2010 | 06:30 AM
  #79
WTEBOY703's Avatar
WTEBOY703
okay i know your tired of explaining and seeing Blown but this is what i found and want to know if this is the proper fan and spal controller? thanks in advanced
Electric Fan
http://www.go-part.com/0608-chevrole...tml?src=become
Spal Controller...but with this do i need the optional temperature sensor?
http://www.a1electric.com/Merchant2/...ode=FAN-PWM-V3
Old Aug 29, 2010 | 11:39 AM
  #80
Blown287's Avatar
Blown287
WTEBOY703, I'm not tired at all man. That fan controller is the same one I installed in Trucky's ride and no you won't need the water temp sensor. The SPAL will allow you to piggyback your OEM sensor and that fan is good to go.
ozone45212, different controller have different color wires but all hook up pretty much the same. There will be a wiring diagram explaining where each color wire goes.
