Turbo Talk
Old Aug 15, 2011 | 09:10 AM
  #191
MitsuRaider's Avatar
MitsuRaider
Well, I got some work done this weekend:
First things first. I drilled into the oil pan:
And boy, am I glad I took it off to do it. I dropped a lot of metal shavings while I drilled the hole:
Here is the oil pan off, clean as a whistle of course, I don’t **** around with oil changes =)
It was incredibly easy to take off!!!!! Just remove the power steering links and cross member and bam!
Here is the hole:
The pump is completely wired. I did not use any resistors or check valves. I ran the truck until it was hot with no pressure issues or leaks.
I’m planning to get the wastegate today as well as hook up the safc. With that done I’ll get everything welded tomorrow and finally BOOST!!!
Old Aug 15, 2011 | 03:10 PM
  #192
remme's Avatar
remme
all looks great, very clean looking. I answered your question on FB
Old Aug 15, 2011 | 04:56 PM
  #193
donkeypunch's Avatar
donkeypunch
King Jackass
Looking good! If you dare make a post saying "Its done!" with out a full picture album and videos....I will just snap.
Old Aug 15, 2011 | 05:50 PM
  #194
MitsuRaider
Thanks Remme, Im tunning with the SAFC for now but I'm definitely going to go with either a standalone, or SCT down the line.
Now i have to do it...
Old Aug 15, 2011 | 08:47 PM
  #195
Eimer123's Avatar
Eimer123
Does the oil pan have a factory gasket, or RTV?
Old Aug 18, 2011 | 12:30 PM
  #196
MitsuRaider
Eimer I removed the old oil pan gasket and replaced it with a new factory one.
I got the truck back from the exhaust shop today. Stay tuned for some pics and videos
Old Aug 18, 2011 | 03:16 PM
  #197
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Very temperamental lately... take heed Nick, I don't want to see the aftermath!
Old Aug 18, 2011 | 06:00 PM
  #198
donkeypunch
King Jackass
Haha! At least someone noticed. Lol. I'm just excited to see the results!
Old Aug 20, 2011 | 01:25 PM
  #199
remme's Avatar
remme
Good move buying the expensive exa-pump. My cheap chinese pos's 1.3gpm isnt strong enough. My pressure switch inline with the return goes off everytime Im in boost, it's set at 4psi. When I let off the gas I get a huge puff of white smoke from my exhaust. Oil is backing up in the line and the turbo is burning it off, went ahead and bought the exa-pump. Should be here by mid-week. On a different note, when your up and running, let me know the difference in psi from your wastegate to your boost gauge. I have a 4psi spring in my WG, the boost controller is at its lowest setting so I should be seeing 4's, at full throttle Im only seeing 2psi. So I'm losing two from th the turbo, prob through the IC and piping. Waiting for the new scav. pump before turning it up....
Old Aug 20, 2011 | 03:40 PM
  #200
MitsuRaider
Hey Remme. I got everything up and running today. Wow does that turbo sound sweet.
Just when i thought I was done...I blew a turbo seal. Started pouring white smoke from the exhaust as well as a small leak from the turbo itself.
My guess is that there is just too much oil entering the turbo. An oil resrictor in between the oil feed and turbo should be the answer.
Hmm its really weird that your oil would backflow into the turbo. After all that pump is barely doing any work, its a very small amount of oil its returning back. As far the the PSI drop. 2 PSI sounds about the right drop you would get from all the piping + intercooler. Time to go up in boost. Just go with a 10 lbs spring, you will be fine. Thats what i have on mine right now.
Im taking the turbo off tomorrow, having it rebuilt on Monday and its back on after that. This time with the oil regulator in place.
