Hemi Swap 1yr Plan
Old Jun 24, 2013 | 07:30 PM
  #231
FrenicX's Avatar
FrenicX
Got the bolts for the stock motor mounts, now I can test fit the motor. I'll do that tonight.
Old Jun 25, 2013 | 12:24 AM
  #232
sleds's Avatar
sleds
Yeehaw!! Nice to see her underway. I'll be doing this in the fall if all goes well. My Hemi is sitting on my shop floor on a pallet right now. It would look alot better in the truck. I'm sure I will have lots of questions for you when it's time. Good luck. Any room for a supercharger in there? Lol.
Old Jun 25, 2013 | 02:16 AM
  #233
FrenicX's Avatar
FrenicX
No problem, I'll be around. There is plenty of room for a supercharger lol. I might be crazy but I swear this is a smaller motor. It's wider down low but narrower up top, a tad longer and a tad taller all together. But it just seems tiny. I guess I'll have to see how it is with everything hooked up.
Now keep in mind this is a test fit, but damn it fits very well. Passenger side bolted right up and I threw 4 bolts in the trans to hold it together. The drivers side will need some kind of mods or a new block bracket all together. I will piece something together with plastic, then cut it out of metal and have a shop weld it for me. Look closely at the clearance between the master cylinder and the back coil.
File Type: jpg
Old Jun 26, 2013 | 10:16 PM
  #234
hendrixx324's Avatar
hendrixx324
I'm so pissed off at myself for not putting this in my truck. 😡
Old Jun 27, 2013 | 01:00 AM
  #235
FrenicX's Avatar
FrenicX
I mocked up some thick plastic engine mounts last night, took it to a fab shop and he's gonna have me an engine mount tomorrow or Friday. It will be made with 1/4 plate so it will be pretty strong. I put the engine back on the stand to I can redo the wiring harness and make it nicer, plus paint over all the rusty welds in the engine bay.
Here's a teaser pic of the engine when I was test fitting. It's almost sad to have it on the stand again lol
Old Jun 27, 2013 | 01:36 AM
  #236
FrenicX's Avatar
FrenicX
Here's a checklist, small things and such that I need to remember to do.
Put OE gaskets on headers.
Take care of rust spots.
take bellhousing guide pins from 4.7
Prime and install torque converter
re-loom harness
extend and splice connectors
fuel line
radiator hoses
power steering lines
Trans cooler
drain excess oil (overfilled)
top off trans
Old Jun 27, 2013 | 08:45 PM
  #237
keilkravec's Avatar
keilkravec
I gotta see the end of this! Great write-up and log of your build man, keep up the good work!
Old Jun 28, 2013 | 07:20 AM
  #238
Blown287's Avatar
Blown287
Looks awesome and good work. I'm glad to see someone doing this and documenting it. Next year I will be looking for another G3 Dakota and doing this also.
Old Jun 28, 2013 | 09:50 PM
  #239
Paulinations's Avatar
Paulinations
I'm thinking about doing this too! I have the 3.7 now...and if I'm gonna upgrade anything i think it should be a hemi...
why didn't they put this in the R/T????
Old Jun 28, 2013 | 09:56 PM
  #240
Paulinations
I'm also just gonna leave this right here:
