Superchips Questions and Updates
Old 09-21-2011, 11:49 PM
MDSBigPaPa's Avatar
MDSBigPaPa
MDSBigPaPa is offline
Originally Posted by MoltenRAMer
I used another USB port. I try to update at a minimum once a month, so when the error codes came up, I got a little nervous...I have not had one issue with this excellent product and am not real computer savy...but your guidance was spot on. So this is an issue that SC is aware of and working on? Just asking out of curiosity.
Yes, they're working on the problem but, they don't have a fix just yet.
  #3122
Old 09-22-2011, 10:03 AM
Scott@Superchips's Avatar
Scott@Superchips
Scott@Superchips is offline
Former Vendor
Thanks for stepping in and helping Mark! You are a great resource here.
Scott
  #3123
Old 09-22-2011, 02:21 PM
SilsHemi's Avatar
SilsHemi
SilsHemi is offline
This is a temporary workaround for the current updater issue.
1) If you want the trans options and can't wait, follow step 1 below. You will need to ask the Superchips representative for a trans tuning waiver form.
2) If you just want to update your tuner, follow step 2 below.
1) To get the trans options under an RA, call in (407-585-7000 or 1-888-227-2447) for an RA, the tuner must be locked / tuned to the vehicle. We will require a signed waiver. We will charge what $39.95 minus the cost of inbound shipping. We will need a copy of the inbound shipping receipt to accompany the tuner. We will ship the tuner back to the customer Fed Ex ground no charge. i.e. $39.95 minus $12.50 equals $27.45 charged to the customers CC.
2) Follow the outlined driver removal instructions: Login to Superchips Easy Update. Connect the tuner. Key Exchange error appears, close Superchips easy update. Click the Start button, right click My Computer and select Manage then click on Device Manager (Device Manager may be different for OS’s other than XP). With the tuner plugged in, expand "Universal Serial Bus controllers" and scroll down to "USB Programmer", right click it and select Properties. In the Driver tab select "Uninstall Driver." You will be asked to reboot your machine. Reboot it and start the Easy Updater software then plug in your tuner. You will see "New Hardware found" and "Installing Drivers." The Easy Updater should then rescan your tuner and proceed with the update. Again upon the completion of the initial update you will again receive the two Key Exchange Errors. Not to worry, the tuner did receive the required update and you can ignore the key exchange errors.
Thanks!
  #3124
Old 09-26-2011, 06:16 PM
BadHazard's Avatar
BadHazard
BadHazard is offline
Default Superchip / reset question
Well I just got my superchip installed. I don't know if it has the advanced transmission setting or not. I went into the transmission setting and selected "Superchip Setting" for upshift @ WOT
If im at a stop light and just get on it a little bit I can totally feel a big difference. However; if I try to break my tires loose (hold break and press gas at same time), I cant. My 0-60times seem to be the same. Im running 91 tune and have a full tank of 91octo. I didn't reset my pcm after the install.
Should I do this to get the full effect? If so how do you reset it? Unplug the negative battery cable and touch it to the body of the truck?
Note: I have 3;55 gears, might have something to do with it.
  #3125
Old 09-26-2011, 07:14 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
Trans tuning is aditional expense. $40 I think?
PCM reset..yes as your trans learns your habits.
I suggest reading through THIS thread I created as it's almost everything you need to know. There's alot to take in and it's a little confusing, so spend time and read thoroughly.
  #3126
Old 09-26-2011, 08:42 PM
MDSBigPaPa's Avatar
MDSBigPaPa
I suggest reading through THIS thread I created as it's almost everything you need to know. There's a lot to take in and it's a little confusing, so spend time and read thoroughly.
Rich, WOW! I just read through your compilation thread of Superchips trans tuning and cannot believe just how much information is contained there. GREAT JOB! And it's right there in one place so the folks don't have to read through the 300+ pages in this thread.
If you don't mind, I'm going to add the link in my signature. If only I could..
  #3127
Old 09-27-2011, 01:38 AM
shrimp_2's Avatar
shrimp_2
shrimp_2 is offline
i never read anywhere that you should reset your PCM.. I've had my programmer for about a month; so should i reset mine or is it fine? if needed to, how do i reset my PCM? thanks guys
  #3128
Old 09-27-2011, 10:05 AM
BadHazard's Avatar
BadHazard
So i did some dataloging
Something is wrong. Here are my 0-60times
9.21 every single time. with and without O/D. When i manual shift it was 9.57
I cant remember exact number but 0-50 was 6.??
What gives? Ideas?? This was with 91 tune
  #3129
Old 09-28-2011, 12:15 AM
MDSBigPaPa's Avatar
MDSBigPaPa
There are several threads on Dodge Talk, DodgeForum and Hemitruckclub that discuss resetting your PCM. The best way, from what I've read and experience, is to disconnect the POSITIVE (+) battery cable and ground it to a good ground for 30 seconds. This discharges the capacitors that hold the charge to retain the learned data and force the PCM to re-learn your driving habits all over again.
Do you HAVE to reset your PCM? No. But it will take a LOT longer for it to discover any engine mods such as: cleaning the throttle body, new plugs, new CAI or CAT back exhaust.
Will it hurt to reset it? No there as well. About the ONLY thing you will have to do is reset the time on your radio.
  #3130
Old 09-29-2011, 06:36 AM
SilsHemi's Avatar
SilsHemi
SilsHemi is offline
That's one heck of a thread there Rich. Well done man!
Quick Reply: Superchips Questions and Updates
