Lowered Trucks: tech and info....
Old Apr 16, 2016 | 01:33 AM
  #1831
Mclemore22's Avatar
Mclemore22
Default Camber
Hi I'm new here but I have a 2008 1500 it's been lowered I think about 4/6 and I need to adjust the front wheel camber need and little help on the best way to do this its adjusted out all the way and still wears the inside of the tires but here's the truck
Old Apr 16, 2016 | 09:57 PM
  #1832
justin0943's Avatar
justin0943
are you sure thats a 4/6 because on my 02 its the same hight but mine only a 2/6 drop and also it depends on what the front drop was done need more details like did you do spindal drop or just cut coils off
Old Apr 16, 2016 | 10:16 PM
  #1833
Mclemore22's Avatar
Mclemore22
Cut a loop and a half out of the coils and took a leaf out of the back and put shackles on
Old Apr 17, 2016 | 04:42 PM
  #1834
justin0943's Avatar
justin0943
thats the reason you cut the coil you did the free/cheap way spend the money on drop kit did mine with 2in spindal drop and flip kit I want to do another inch on the front an also I still haul a trailor around
Old Apr 21, 2016 | 03:56 AM
  #1835
Mclemore22's Avatar
Mclemore22
Iv been thinking about getting 2" drop coils and 2" drop spindles belltech has them both that'll probably be the way I go
Old May 10, 2016 | 02:36 PM
  #1836
sbecknal's Avatar
sbecknal
Default My Dilemma
Replaced rear shackles with 2" drop shackles and also removed the helper spring but still sitting at same height as before. Changed the sway bar to neutral position thinking this was holding it up but still no luck. Any one have a suggestion. Only other thing holding her up is the shocks.
Old Mar 31, 2017 | 04:33 PM
  #1837
hemibee's Avatar
hemibee
Cool lowered trucks
did 2/4 drop on my bee back in 2004 front drop spindle 2'' - 4'' lowering leaf springs on the rear end & drop shocks all around. rides good. just got my factory 20s off and got some after market rims from dicount tire. they look like factory R/T RIMS. but are powered coated silver/mach'd finished
Attached Thumbnails Lowered Trucks: tech and info....-003.jpg   Lowered Trucks: tech and info....-005.jpg
Old Jul 14, 2017 | 01:04 PM
  #1838
jacmates's Avatar
jacmates
Question Lowering of 2005 Dodge Ram Quad Cab
What would be the best approach to lower/level a 2005 Dodge Ram Quad Cab. I have 17 inch tires. Should I get 20 inch tires/rims or should I lower it by purchasing a lowering/leveling kit. Thanks.
Old Jul 14, 2017 | 01:42 PM
  #1839
2 or 4 wheel drive?
Old Sep 4, 2017 | 09:27 PM
  #1840
mdmachiavelli's Avatar
mdmachiavelli
Are they 22s?
